Question about Samsung SYNC SGH-A707 Cellular Phone
Mp3's how can you remove an excerpt from an mp3?
    Problem Solver:
  • 6 Answers
I've been using a free audio editor program called Audacity to make my own custom ringtones for myself and daughter for months now.  With it you can trim any part of an mp3 or I think wave file and export it as an mp3.  It took me awhile to figure it out (mostly because I was too lazy to read the help files), but it indeed works, and is totally free, no spam,no spyware.  Depending on your setup you may need to also download the lame mp3 encoder, it's listed under "optional downloads", and instructions are there too.  Have fun!
http://audacity.sourceforge.net/download/
Posted on Oct 11, 2007
    Problem Solver:
  • 6 Answers
You cant on the fone itself may have a program on a computer where you will be able to then send it back to the fone
Posted on Sep 30, 2007
SOURCE:
How do I reset my sigh-in Passcode
"If you forget your password, try looking at the password hint you entered when you created your password. If you still don't remember your password, you must call Kindle Customer Service for help with resetting your device. Keep in mind that when you reset your device, you will lose any personal documents, periodicals older than the past seven issues, MP3 files, and Audible files that you have not backed up."
Excerpt from http://kindle.s3.amazonaws.com/Kindle_Users_Guide_5th_Edition.pdf
Good luck.
Mar 15, 2016 | Amazon Kindle 3 Wireless Ebook Reader...
My password/s don't work esp Google after they are they are excerpted
I forgot my password when I wenttl my email I couldn't get the message to set my passward
Jan 30, 2014 | Computers & Internet
Need to replace a front heat blower resistor on 2002 mdx, where is located???
moz-screenshot.pngHere's an excerpt from the 2002 Acura MDX 4WD 6cyl Repair guide for replacing what the reference manual calls the "control assembly" - its located under the console rear trim and may (or may not)
contain the blower resistor - my manual doesn't say - but this is the closest thing I could find for you. Every other blower resistor I've had to find was located close to the heater controls - and this
car seems to be no exception -- its heater controls are located in the console between the seats, rather than in the dash (as in Acura 2003-06 MDX models).
You may want to call your friendly Acura dealership ad speak to the parts department, to make sure where the blower resistor is located - or a visit to a dealership parts counter often (or
Advance Auto Parts is helpful too) ofen clarifies questions I have from Haynes manuals (the cheapest car repair guides).
All this assumes that you've correctly diagnosed your blower control problem -- as in "replace the blower resistor when the blower works only on the MAX/Highest setting."
-- begin excerpt from 2001-2 Acura 4wd 6cyl MDX Repair manual --
Control Assembly Removal & Installation
2001-02 Models
  1. Remove the console rear trim. Refer to the accompanying illustration.
    Fig. Exploded view of the console rear trim
  2. Remove the self-tapping screws and the rear heater-A/C control unit (A) from the console rear trim (B).
To install:
  1. Install the control unit in the reverse order of removal. After installation, operate the control unit controls to see whether it works properly.
  2. Run the self-diagnosis function to confirm that there are no problems in the system.
    Fig. Remove the self-tapping screws and the rear heater-A/C control unit (A) from the console rear trim (B)
  3. --- end excerpt from 2001-2 Acura 4WD MDX 6cyl Repair Manual ---
Jan 02, 2011 | 2002 Acura MDX
Marantz cdr420 recorded media stored on harddrive.played back all fine unplugged now it says no valid files when i try to burn the disc but the drive reads full.
If you are attempting to burn mp3 files as an audio CD, then that's the problem. You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
May 04, 2010 | Marantz CDR420 CD Recorder
No Valid Tracks or No Song Select
Feb 14, 2010 | Marantz CDR420 CD Recorder
How do i get my videos to show on my RCA ipod?
I am assuming based on the picture that you have some variant of the RCA M42XX, not an iPod (If you have a different version of an RCA mp3 player, the answer below remains the same).
In order to transfer videos to your player, you need to use the easyRip software's Player Loader module. It will convert the compatible videos (if it can play in Windows Media Player, it should be able to be converted and played on your device) and transfer them to your device for you.
Further instruction is provided in the easyRip help module that you can access by clicking on the icon on the easyRip Module Dock with the '?' symbol on it.
An excerpt from the help:
Load Media Player with Selected Files Step 1. Connect the media device you want to add the files to.
Step 2. Select which portion of the PC Library you want to select from using the "Your PC Library:" drop down menu.
Step 3. Select which files to load by adding or removing the "x" control associated with each file. The "x" can be toggled on and off by left-clicking in the box of the media item you want to select (display the "x") or deselect (not display the "x"). Note: An "x" indicates the file will be loaded. (IN YOUR CASE IT WILL BE THE VIDEO OPTION FROM THE DROP DOWN MENU)
Step 4. Select the "Load Player with Selected Files" control.
Oct 22, 2009 | RCA M4208 MP3 Player
I keep getting an uncaught excerption error, can
software has to be reinstalled with the help of Blackberry desktop Manager....Backup cannot be taken
Oct 21, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I dont know how to download music to my mp3 player
excerpt from manual @ nextar.com
Q. How do I copy/transfer files to my MP3 player?
A. There are many ways to copy /transfer music to your player. Here¡¦s a common and simple way to do this process using Windows Explorer. Follow the instructions below: -Connect the disk storage (MP3 player) to your computers USB port. If the computer pops up a window asking what do you want windows to do? Click cancel. -Right click on My Computer and click on Explore. A split window will pop up and display the contents and drives on your computer. Look for the drive Removable Disk (E:) [The letter drive may vary depending on your computer] This is your MP3 player. -Next, drop down My Documents and click on the My Music folder. If you store your music files in a different location then find that folder. -Take a file from the My Music folder or where ever you store your music files, click on the music file drag and drop it into the E: Removable Disk on the left of the window. A window will pop up and display the progress of the copying. Repeat the process until your player is full. You have completed the file copy/transfer process!
May 06, 2009 | Nextar MA933A MP3 Player
Excerpting a song on iTunes
You would have to go and buy or illegally download a music editing software. There's no other way of doing it. Not with iTunes or Windows Media Player.
Thank you and please respond with any comments or more questions.
-John-
Feb 15, 2008 | SanDisk Sansa e250 MP3 Player
Samsung SYNC SGH-A707 Cellular Phone Logo
78 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
