Question about Brother HL-2040 Laser Printer
BROTHER HL-2040 LASET PRINTER DRUM,TONER,PAPER,READY LIGHTS GLOW CONTINOUSLY.HOW I SOLVE THIS PROBLEM TELL YOUR SUGGESITION TO MY EMAIL
  • Anonymous Apr 17, 2009
    i want the driver software quickly as soon as possible bcz i wannan print an important file today bfre 11:25 plz gv it qucly
    bye
    t.c
  • 133 Answers
Please try to hold on the "start" buttom for 1 min until the 4 lights on.
I hope this works
Posted on May 23, 2009
Why won't it print?
Brother HL 2040 Laser Printer Repair solution - YouTube
? 2:25
www.youtube.com/watch?v=t4GGvm3aW7c
Oct 25, 2012 - Uploaded by nobblynoel Brother HL 2040 Printer Repair solution for multiple page jams For more Info ... My Brother HL2030 laser printer is making a groaning/grinding noise on ..... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ...
Aug 07, 2015 | Brother HL-2030 Laser Printer
I have a Brother HL - 2040 printer. It has been turned off. Having switched it back on I now have the Toner, drum and paper lamps on and it hasn't warmed up. Does this mean I need to purchase a new...
If all the LED's are flashing and continue to flash for more than 10 minutes with the unit powered up, it needs to be serviced or replaced. (That is toner, drum, paper and the Ready light all blinking -> critical error found in self-test.) If the Ready light is off and the rest of the lights are steady, the toner is out, the corona wire needs cleaning and the paper tray either is empty or not picking up the paper.
See http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11 for details on the errors and solutions.
I hope this helps.
Jan 27, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
How do I pull out the toner cartrige of a HL 2040
Front panel of printer (manual paper feed is in the middle of this panel) has tabs on the right & left and will fold out and down. The toner/drum is right inside. there's an opening in the middle to grab it and pull straight out. The toner will separate from the drum unit by holding a small purple/blue tab on the left side down, and then lift up and out. Reverse this when putting everything back. remember to shake the toner right-left to loosen the toner before putting back in the unit. To reset the printer, and with the front door still open, hold the GO-Control button down until all lights are on, then let go, close up front door. Power off & back on and you should be set.
Jan 05, 2010 | Brother HL-2040 Laser Printer
Lights on printer will not go off when turned on.
may ur printer ink is finished. check ur ink in printer.
Jul 12, 2009 | Brother HL-2040 Laser Printer
My drum light is staying on on my brother HL2040 printer. I just replaced the toner a week ago, and now the printer won't pull paper or anything.
Try this,
Push and hold the "start" buttom for 1min until you see 4 lights on.
after that your printer will be reset and should be ready to use.
Apr 30, 2009 | Brother HL-2040 Laser Printer
The paper light blinks continously on my Brother HL2040 laser printer even though I have paper in the tray. I have changed the cartridge and drum and changed the drive settings as someone else had...
Did you try to reset the printer?
WIth the printer ON
Open toner-drum door
Hold GO button until all four lights are on
Release GO button
Close door
Printer will cycle through selftest and all lights will be reset
Apr 18, 2009 | Brother HL-2040 Laser Printer
All LEDs are flashing
If you hold the two buttons down, this will give you a secondary error code which will tell you the exact error. All lights flashing is a service error.
Aug 27, 2008 | Brother HL-2040 Laser Printer
Brother 2040
Broken carona wire in drum replace drum or non gen toner not working correctly
Nov 13, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
322 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
