Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
HIGHPITCHED WHINING SOUND AND COLOR FADES IN AND OUT
PROBLEM JUST STARTED, NOISE IS IRRITATING AND SEEMS TO COINCIDE WITH COLOR PROBLEM. NOISE IS COMING FROM THE BACK OF THE SET.
  • 201 Answers
Well in case you didn't get an answer somewhere else the part making the noise is called the color wheel and has a motor that spins it at a high rpm. When they go bad they squeal real loud. You're looking at maybe $300-400 to fix parts and labor.
Rustym62
http://www.the-tv-dude.typepad.com
Posted on Apr 26, 2009
My Image 15.or treadmill makes a loud, whining highpitched sound when operating. Should it have lubrication?
LUBE the deck belt + rollers bearings .However test the rollers bearing main motor.
If the problem persist time to replace the deck belt old board.
God bless you
Jan 25, 2013 | Exercise & Fitness
Aircondition makes whining noise
It would depend on where the noise is coming from.
Could be a belt, the compressor, or the blower motor.
The blower would be noisy in both ac and heat mode.
Sep 08, 2012 | 2009 Volkswagen Tiguan
There is a whining sound upon powering up my HL-P6163W which softens after about 5 minutes, but doesn't disappear completely. I think the source is either the color wheel or the cooling fan. How can I...
It the Colors wheel,cooling fan will shut down,if it start making noise to the fan,because the whole projection egine and the bulb link to it.The fan have to run a certain RPM to keep the tv running without problems.These colors wheels run 1000 RPM to start to give the tv colors and it make out Flexy glass and plastics.What ur opinion,who will give u the problems,first as parts wise.Ok any noises like whinning in the tv alway the colors wheel starting to buckle and warp.Getting worse make motor noises and briddles enough will brake and shatter it into ten of hundred of pieces.Who know,than inside what else will cause the rythum of the RMPS running of the tv,when u replaced it.
Jul 31, 2010 | Samsung HL-P6163W 61" TV
Amtrol Boilermate makes whining noise
I had also this problem before, same with buzzing sounds on my Amtrol Boilermate and all I had to do was to call the local dealer and they have got it fixed.
May 05, 2009 | Emerson Part UWL Chrome Ultrasystem water...
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Whining sound from front passenger side.
Check the condition of front disc brake pads, if they are in need of replacement a preset little metal arm starts rubbing the discs and will make a whining noise. It doesn't do any damage but it's irritating to listen to.
Nov 25, 2008 | 2000 Saturn Ls 4dr Sedan
Transmission, transaxle, transfer case
have the rear wheel bearings checked they had a recall on them they get water inside and rust up and whine please rate and good luck -jeff
Sep 05, 2008 | 2006 Suzuki Grand Vitara
Whining noise problem and color flickering
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
Strange noise
Some vehicles increase sound while you accelerate. There should be an option in your head units settings (not your sirius unit) to turn it off. It may be causing the whine.
Jun 04, 2008 | Sirius Stratus 4 Satellite Radio Receiver...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
