Question about Car Audio & Video
Adding amp and speaker, no rca amp jacks on back of radio
I would like to install an amp and bass speaker in my 2009 v6 Mustang. It has a basic single CD/MP3 radio with aux in. Not a Shaker 500 or 1000
    Problem Solver:
  • 6 Answers
Well you can installl anything you want into your vehicle you just need to know how!!
Posted on Apr 14, 2009
Power but no sound help plz....
well here we go how do you have your pioneer radio connected .
did you run the radio speaker wire out to the factory speaker or did you have an amp connected to the rca output jacks.
1 well if the radio connect by the speaker wire out the
output chip in the radio is fried and needs repair ....
2. if u have a amp connected to power your speakers for sound
check the amp to make sure you have power and no lose connection or speaker wires disconnected.
3. it also possible that the rca jacks are fried too
I no by experience that pioneer loses ground on the audio output jack (rca) well what we did to fix it is..
take and 18 gauge wire stripe back about 1/2" to 1" of the insulation to expose the copper wire and wrap this around the metal casing of the rca jacks and then ground the wire to a ground point do this for both left and right rca jacks...
radiorepair@windowtintingin239.com
Oct 30, 2013 | Pioneer DEH-P3500 CD Player
I reset my radio and my subs stopped working, i used to have the option to adjust the use of the sub woofers where you can adjust the bass, treble, and balance but when i reset it the option just...
Check the fuses , on unit , then your amp. And did you use a remote to reset the radio ? Also check RCA jacks on the back of the radio !
Sep 25, 2013 | Car Audio & Video
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
How do i install amp
Hi. First find a place to mount your amp. You must run a cable for the of the battery directly to your amp and place a fuse in line, by the battry. The ground cable must be as short as possible. Then run your rca cables from your radio to the amp and a single cable to use as the remote cable. Now connect your speakers. Make sure go's to from amp to speakers. Depending on your radio, but most of them have a blue wire in the radio harnes, it is the remote wire. Now connect to the remote wire you ran and to the amp. Plug in your rca cables and you are ready to play. Any problems you can email me on faisal-duffin@mtn.blackberry.com
Nov 12, 2011 | Car Audio & Video
I wanna put it into my car myself but dont know how and was hoping for a lil instruction
you will need a amp install kit witch comes with a 15 ft patch cable power line for amp and a blue line for remote. these wires run from the radio to the amp. The blue wire is called remote it turns the amp on or off depending on the radio state. the patch cable is rca jacks on both ends the back of the radio should have the female part of the rca jacks hanging from it. The other end goes into the amp. and last but not least the heavy red wire will go from the battery to the amp usually there is a fuse holder that you need to put between the battery and the amp. As far as grounding just ground the amps negative to the car chasis some where.
Good Luck Hope this helps
May 04, 2011 | Visonik Dual Bass Box with Amplifier Car...
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
2000 mustang convertable amp problems
Are you sure the amplifiers are trashed? Have you checked the fuses? A reputable car audio shop could help for a fee of course, but it may be worth the price. It's odd that (all) the amps would malfuntion simultaniously unless someone unqualified messed with the wiring or the radio has a defective trigger wire (turns the amps on). You'll be sadly disapointed with any new radio without the factory amps, especially with the convertable ... I strongly suggest getting the amps (the factory system) working again.
Apr 17, 2009 | Metra Turbowire 70-5605
Unwanted bass coming out of my subs
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Feb 24, 2009 | Kenwood eXcelon KAC-X812D Car Audio...
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
Car Audio & Video Logo
106 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
