Question about Sony Playstation 3 (PS3) Console
OUTPUTS DONT WORK?
Ok so well. I bought the component cable for the ps3 and my hdtv and it works perfectly fine. but if i take it and connected to a normal tv with the stock outputs it came with. it doesent work. i don't know if my ps3 is damaged...or whats the problem?
  • 752 Answers
Hook it back up to the HDTV and get into the menus. Get into the video menu and make sure that it is NOT set for progressive scan (normal TV's are Interlace).
Posted on Sep 13, 2007
SOURCE:
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Playstation 3 does not output to my Mitsubishi 62825. It has in the past. I've tried RGB and component. Neither work. Using the same cables it works fine with my girlfriends Sony Bravia. The tv has...
Is your girlfriend's television higher resolution? If so, the ps3 may be configured to output a signal that is too high for your mitsubishi. With the ps3 off, insert either the component or the rgb to the back. The turn on the main ps3 power switch so that the red led turns on. then hold down the 'power on' button. it will beep initially, then beep after about 3 seconds. This simply resets the output to the connected cable in a normal resolution.
If this fails go to settings>video output> and play around with the settings there. note you may have to do this on ur girlfriends tv to be able to see what you're doing...
Aug 26, 2011 | Mitsubishi WD-62825 62" Rear Projection...
Sony trinitron kv-32fs10 component color problem
check the av in puts of your tv, this sounds that your av jack has a loose joint on the connection under.
May 24, 2010 | Sony KV-32FS10 32" TV
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
HDMI Connection to Ooptical Output
Talked with Sharp, it's a issue with hdmi and optical out, best fix for it that I'm currently using is a 3-way toslink splitter, cost a little of nothing and work perfectly, you just turn the dial to the signal you want to play off of. Clicky
Jan 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
No sound from HDMI to PS3
go under system setting-->select sound settings-->select audio output settings -->hit x on hdmi-->hit x on automatic-->hit x to enter. This solved the issue for us :)
Dec 04, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
