Samsung MP0804H not working
Samsung hard disk drive external (MP0804H 80GB) is not recognised by the system. Although the same worked fine earlier. May be the trouble started after the updating the system. I am using Windows XP Professional (SP3). How can I correct the system configuration.
    Sniper:
  • 68 Answers
Try the had disc on a different computer and if it works hen ok..... otherwise ........... sorry................ If the hard disc is working then use windows Xp SP2.
Posted on Apr 15, 2009
I have a brand new samsung G2 500gb (MU050DC/GB) external harddrive and I want to use it to transfer between computers (work and home). My work laptop operates Win7 and recognises the drive. I have WinXP...
A computer that is running Windows XP cannot detect a USB flash drive, an Apple iPod, or an external hard disk drive
To fix this problem, delete the UpperFilters registry value and the LowerFilters registry value. These values may cause access problems. (from Microsoft website)
http://support.microsoft.com/kb/925196#letmefixit
Jul 11, 2011 | Samsung G2 Portable External HX-MU050DC/...
I have a Fujitsu 80gb Sata hard Drive (2.5) which I have an adapter to use as a external Harddrive. However my computer and others only recognise it as a 14 gb drive. How do I get the full 80gb?
It seems this is caused by setting jumpers on your hard disk. Checkand return it to the correct position. Normally, your disk should be inthe position of Master or Slave.
Jan 16, 2011 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
How to replace the power module for external hard drive. I had take it to Best buy and they said the disk is fine (although cannot see any data). He also said that the power system is bad and he can put it...
> cannot see any data
Is that what you expected?
Or, are you sure that you have written files to it?
> put [the 80GB disk-drive] in a new box for $40
That's slightly above a "normal" price for an "empty" external hard-drive, but if the price includes "labour", then $40 is a good price.
But, if there really is "no data", then it's time to buy a complete brand-new external drive -- $100 will get you 500GB, with a 3-year warranty.
Apr 10, 2010 | SmartDisk FireLite 80 GB Hard Drive
Samsung MP0804h
You dont say what you've tried already. Have you used the add hardware wizard in control panel.? Have you checked your BIOS settings to see if enabled & computer can see it.? Tap delete key during initial power up of computer is usual route in.
Sep 28, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
Formatting a Samsung MP0804H IDE extrernal HDD from NTFS to FAT32
Hi there Dave, well you can use a software called Partition Magic 8 to convert your 80GB hard disk to utilise FAT32. This software is quite user friendly. There are several options for you to choose form in this software including resizing your drive and creating partitions on the fly. However some settings requites a computer restart or reboot in order to complete successfully. This software can be obtained from most software stores or even download form the internet. After installing the software and running it, your drive should show inside the programme; right click on the drive you want to change a setting and select the options available. At the 'Format' button select FAT32. You will be asked for drive letters and cluster size but you can use the default settings, then apply the settings. Once you are done with that select the Okay button in the main programme window and the formatting process will start. Hope this helped you. Cheers :-)
Feb 02, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Samsung Hard Disk MP0804H
maybe your HDD are not compatible in your laptop. try to look it in your manual if it is compatible or not.
Jan 29, 2009 | Samsung (MP0804H) 80 GB Hard Drive
External hard disk and pcmcia cardbus
There may not be enough power from the cardbus to run it. That bus is very low current to power it up so you will need the power cord.
Try reinstalled the card drivers.
Aug 04, 2008 | Computers & Internet
See only one of four partitiona in a mobile disk
Go into the control panel.
Go to administrtive tools.
Go to Computer management.
Click on disk management on the left side of the screen.
Click on the drive you partitioned.
Does it show four partions?
Were they partitioned as NTFS or a different format?
Jul 16, 2008 | Samsung (MP0804H) 80 GB Hard Drive
PC not recognising the slave drive
Assuming you set it as slave or cable select as required by the motherboard, you have to first get the bios to recognise it press F2 or Del on boot up to enter cmos and then there should be an option to auto detect drives, save settings for a re boot. When in windows, right click on my computer icon and select manage>disk management and then your drives will be listed, right click on the slave drive and select format or set as active and it will then show, but only 137GB may show depending on the bios version.
Oct 03, 2007 | Samsung (MP0804H) 80 GB Hard Drive
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
