Acer AX1900-582G50mi PC Desktop, Intel Pentium Dual Core E5800 3.2GHz Logo
A
Anonymous Posted on Sep 06, 2013
Acer ax1900 power supply - Acer AX1900-582G50mi PC Desktop, Intel Pentium Dual Core E5800 3.2GHz
Acer PD528 Power Supply
It will be better to replace the power supply boards to PDPs, rather than trying to repair it.
1helpful
No Internet after thunder storm
possible the storm may have blown out your ethernet port on the desktop, router, or modem. It has happened to me once before.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Modem not working
call you internet provider to get the modem replaced. Usually it's the Ethernet port on the modem that has been damaged from the storm.
4helpful
I have an Acer Aspire AM1641 U1521A desktop that will not boot up. No beeps, errors or monitor activity. Do I need a new hard drive, motherboard...?
Power Supply. Weak voltage power rail.
Has enough power to light LED lights, maybe spin fans, (Or spin a few times, and stop), but not enough power to turn the Processor on.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Depends on what Processor it is.
Acer Aspire M1641-U1521A?
Intel Pentium Dual Core E2180 (2.0GHz)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
Can use up to 65 Watts. (TDP)
The Power Supply used is a 250 Watt unit. Acer isn't known to use high quality power supply's. It's a generic low quality Power Supply.
[ However in all fairness to Acer, if the inside of the computer, AND the inside of the Power Supply, isn't cleaned out on a regular basis as needed, this can cause Power Supply failure also.
Use a can of compressed air for computers, with the plastic 'straw' attached. Hold onto the can with one hand, use the other hand to hold onto the straw, shoot air through the ventilation holes of the Power Supply's case. (Computer unplugged from power)
Come around to the back of the computer, use the air to clean the Power Supply's fan blades, center hub, and surrounding cage. (Shroud)
When the cooling components for the Power Supply, (Fan and Heatsinks used inside), become clogged with dust, dirt, etc., the cooling capacity drops tremendously.
The Power Supply overheats.
Heat = Wasted Energy
The Power Supply strains to keep up with the call for power, but eventually cannot, and fails.
Components inside the Power Supply fail ]
Replace the Power Supply.
2answers
How can I reboot my acer M661? The power light is on but will not boot.
1. remove the battery
2. Press power button now. keep power button pressed for 2 mins
3. Reseat the battery.
see if it works !.
Happy Computing. !!!
Else please aloberate.
4helpful
2answers
Are PC power supplies generic?
According to Acer's website:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM5100/AspireM5100sp2.shtml
The computer uses an industry standard 250W power supply so yes as long as you buy one that has all the connectors you need then you'll be fine.
2answers
I am looking for the model number of a power supply for an acer ax1200. I need to replace it but I can't find the model number to search for a new one.
look on google for power supplies for acer ax1200 or go to acer site. you will find when you do the google search, many sites that may have it, just do good price checking.
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Power supply
you may try to use a universal power supply adapter by APC! check with ACER web page for the your acer monitor voltage and amperes!
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
