Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Kenmore ultrawash dishwasher
By sweetevil on Sep 12, 2007
My disherwasher is not draining ,do i have to take it apart to clean a screen or something?
Comments:
Sep 15, 2007
- ya i got it fixed! Somehow half of a peanut got into the drain line right before the hose at the bottom of the dishwasher.Works great Now!!! thanks
Same Problem
Apr 06, 2009
-   the control lock light will not go off or allow me to choose any settings
-   mrspage
Feb 25, 2009
-   I have a Kenmore Ultra Wash (1576) and the water won't drain properly. I took off the drain hose and was clear. I am wondering if the part (plastic) that attaches to the hose (connecting to the dishwasher) can come out and be cleaned? Does it pull out or screw out? Thank You!!-   billbe2001
Dec 09, 2008
-   How do I go about checking/cleaning the drain line? -   crawf529
Jul 30, 2008
-   my dishwasher wont drain. it runs okay then when the cycle is over about an inch of water stays at the bottom and eventually starts smelling awful.-   clopez
Jul 09, 2008
-   I have a Kenmore Ultra Wash 655 Series Dishwasher that has water in the tub and appears to have no power. I checked the fuse box and the wall plug and both have power to them.
Is there a fuse in the dishwasher control panel to check also?-   wcoleman10
Best Solution
posted on Sep 13, 2007
Helpful)
dovi
Rank: Guru
Rating: 88%, 2494 votes
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Dec 01, 2008
Somewhat Helpful)
titanservice
Rank: Apprentice
Rating: 80%, 2 votes
I cleaned out the drain exit...not the hose but where the hose connects. found all kinds of debris. I used the baster cleaner. (thin brush used for cleaning out the large syringe you use to baste a turkey).
Anyways works geat now!
Was this helpful?
Yes
No
Solution #3
posted on Nov 07, 2007
Somewhat Helpful)
marinegirl
Rank: Apprentice
Rating: 75%, 1 votes
do what dovi says, had the same problem, the repair man wanted 159.00 to fix it, but when I said I did'nt have that much to pay, he showed my daughter where the hose connected and how to fix it, she took it off, cleaned it out, and voila! fixed my 2 year old GE Naut. Dishwasher.
Was this helpful?
Yes
No
Solution #4
posted on Aug 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It can also be a stuck selonoid valve. Some dishwashers have them and open to allow water to drain. If they fail, it is usally in the closed position. Power is applied to open the valve. I checked it with the volt meter and it showed it had failed. I replaced one a few years back on a Kenmore unit in about 20 minutes. The part was not that expensive. If you check the drain line, and all is well there, the solenoid valve would be my next place to check.
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
what brand dishwasher should i buy?
Answer
What new dishwasher do you recommend. I have a family of 7 and the dishwasher is constantly in use.
Answer
Is there a replacement door for a Kitchenaid kudi01tjwh0 dishwasher made of stainless steel? Maybe... (More)
Answer
dish washer wont drain what do I do , whirlpool model du915 leaves water in bottom after cycle... (More)
Answer
E4 fault showing machine beeps
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 09, 2008
My Kenmore Ultra Dishwasher will not drain after all cycles. I checked the drain line from the drain valve to the disposal and it is not clogged. I put a pan under teh drain valve and ran it threw the drain cycle and nothing. Any suggestions.
Comment by Guest, posted on Dec 06, 2007
1996 kenmore ultra wash dishwasher does not drain out all of the water at the end of the wash. all cycles. outlet hose goes directly into sink drain, cannotsee any blockage. tried vacuuming the outlet. nothing
Comment by gwatt, posted on Dec 05, 2007
I have the same problem with the dishwasher not draining, but it's not happening all the time. Sometimes it drains, sometimes doesn't. I have checked the drain line into the plumbing, but not the internal drain in the dishwasher. I thought that if it works sometimes, then that's probably not the problem. I will check it.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
