i am trying to attach a hi-speed usb2 multi port to my usb port on my laptop. when i do this, the computer freezes. can you help me so i can attach devices to the multi usb2 device without any problems?
Comments:
Sep 16, 2007
- 2.o
Sep 17, 2007
- computer still freezes when the usb hub port is attached
Sep 19, 2007
- toshiba satellite p15-420. the thing is; i am trying to attach an external drive to my laptop. every external device (dvd writer,hard drive,pda) all work fine before. now all i receive is a hub port limit exceeded error that won't go away.
-   Hello guys,
This problem is happening to me as well. I have a compaq evo n610c (win xp and 1,25Gb ram) and I bought a external hard drive seagate with 500Gb. However when I plug it on my usb port, after about 1 minute my computer freezes.
I tried everything (re-install drivers, change the usb drivers to win xp standards) and I realized that when I disable the "NEC PCI to USB Enhanced Host Controller (B1)" it works fine but with no USB 2.0 support (it is impossible to transfer big files to my external HD).-   JoaoNeto
What speed is the USB port on your laptop? Is it 2.0? or 1.0?
Comments:
Sep 16, 2007
- Try reinstalling the usb drivers on your laptop. Make sure all udb devices are unplugged. Go into the device manager (right click my computer select properties, select hardware, click device manager.Delete all the usb listings under the Universal Serial Bus Controlers heading. Then reboot your computer all the drivers will be reinstalled then connect your usb multi port unit to your laptop.
Sep 18, 2007
- What is the brand and model of the laptop you are trying to connect to?
Sep 24, 2007
- Are you saying that everything you plug into the usb port gives you that error?
I need to configure my webcam on my emachine netbook I c it in the start menu but it won't detect it...
(More)
I need to configure my webcam on my emachine netbook I c it in the start menu but it won't detect it thru chat????-melodynme
Checked my RAM and I still get one beep code and the laptop will not boot, it just starts to boot...
(More)
Checked my RAM and I still get one beep code and the laptop will not boot, it just starts to boot and I get one beep with nothing on the screen..? HELP...!?
I have an emachines d620 and can't get it to start. It says to check cable and it also says cannot...
(More)
I have an emachines d620 and can't get it to start. It says to check cable and it also says cannot find program. What can I do?
