Question about Electrolux Vacuums
Hi, im hoovering my mothers house whilst she is away, using a vitesse pet lover, but now the cylinder is full and i can work out how to open it so i can empty it. thanks
    President:
  • 389 Answers
Lift the catch where the canister lid joins the handle, then pull the whole assembly away from the handle.  Take the assembly to wherever you want to empty it, then press the button at the bottom front of the canister.  The bottom swings down and the muck falls out.  In the ideal world, you will then take the lid off by twisting it slightly anti-clockwise (you'll see the "lock" and "open" markings on the canister rim), remove the pleated filter (again by twisting anti-clockwise), give it a good shake and then brush between the pleats.  Reverse this process to put it back together, and away you go again!
I hope this helps. Any more questions, just ask. Please remember to rate my response, thank you.
Posted on Apr 16, 2009
Hoover promax pet shampooer is not sucking up water
It is most likely clogged in the tube. You need to take the hose off and run hot water through to see if the water comes out right away, if not you have either dirt or clumps of pet hair stuck. Good Luck
Mar 23, 2015 | Hoover Vacuums
My electrolux vitesse pet lover 1800w has stopped working
Is the flex all right? Check it with a voltmeter or a continuity meter (available for a small sum in your local hardware or electrical shop).
Jan 19, 2015 | Electrolux Vacuums
Electrolux Vitesse Pet Lover 1800w. I was given this vacuum today. It works fine but is really loud. It's hardly had any use. Is this normal? I just put in ear protection.
Should not be that loud. Check all the filters and see if they are ok. Check to see what the suction level is. This is kind of subjective. IT might have a bad bearing in the motor.
Nov 18, 2013 | Vacuums
Motor sounds like a airplane
It sounds like it is time to replace the motor. You might also want to think about replacing the unit itself since the motor can be very expensive in comparison to the cost of the vacuum itself. I would recommend thinking about a different brand like electrolux or hoover.
Oct 31, 2011 | Eureka 3276AZ Pet Lover Bagless Upright...
I am trying to get a user manual for an Electrolux Vitesse 1600 upright vacuum cleaner for my mother in law. Thanks
I've been trying to get a manual for my mother in law for years ;)
You didn't specify a model number so I'm not sure this is the correct manual, but it is for an Electrolux Vitesse 1600w upright. This manual is for model number Z4703AZ:
http://www.electrolux-ui.com/2007/755/98BEN.pdf
Click the link and the file will open. You can then view, save and/or print the manual. If you are unable to open the file, you may also need to download Adobe Reader:
http://get.adobe.com/reader/
If you have a different model, please post back with your correct model number and I will provide a link for the correct manual:
Please rate this solution if you find it helpful. Thank you.
Nov 03, 2010 | Vacuums
Electrolux vitesse pet lover 1700w. Keeps cutting out and electrical sparks in front vent
Hi there SmartAlec from NelsonVacuums.com.au here. I am sorry to be the bearer of bad news but if you can visibly see sparks and its cutting out then i would say that the motor brushes are nearly worn out. On this particular vacuum cleaner they are not sold as a spare part so i think it would need to go to a repair center for a new motor or to vacuum heaven for a replacement.
Regards Alec
Aug 23, 2009 | Electrolux Vacuums
Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux Vitesse Stairmaster 1800W
take it back for a refund and buy another make I have had one also my daughter they are hopeless, they work for 7 minutes then cut out. Not fit for purpose, Electrolux are not interested in solving their problems
Sep 13, 2007 | Electrolux EL1000A2 Pronto Bagless Stick...
Vacuums Logo
138 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
