Question about Apple MacBook Mac Notebook
IStat reads 126 degrees on Macbook - and gets very slow
Could this be my problem? My computer gets very slow and the fan kicks in and gets very loud. This often happens all the time and especialy when watching videos or looking at photos
Is Apple’s shutdown fix crippling MacBooks?
Apple Computer (AAPL) issued a software update Thursday to fix a problem that caused hundreds of newer MacBook laptops to shut down suddenly — but one longtime industry analyst suspects Apple’s solution might force the computers to run more slowly.
An Apple spokeswoman would not provide details about what was causing the shutdowns, or how the software update corrects it.
According to the site MacBookRandomShutdown.com, which emerged over the past few weeks to document the problem and draw Apple’s attention, more than 1,500 MacBook users have had their laptops suddenly turn off. Many took the time to list their names, MacBook models, and serial numbers on the shutdown site.
Rob Enderle, principal analyst with Enderle Group, said that based on user comments in Apple’s online support forums he suspects the laptops have been shutting down because of overheating problems with the main logic board and “heat sink,” a device that’s meant to cool the machine.
“What they appear to be doing is doing a firmware update to step down the processor,” Enderle said. “If you can step down the processor, say, 5 or 10 percent, you can lower heat dramatically.”
But if indeed Apple is doing that, another result is decreased laptop performance. Enderle likened it to throttling back a V8 engine to make it behave like a V6. It won’t get as hot, but it won’t go as fast either.
  • 2 more comments
  • tmcalder Apr 14, 2009
    Can it be fixed?
    It used to work fine, but now I can hardly do anything without setting the fan off and then everything gets very choppy and freezes up for a bit.
    Even when my laptop is cool - when I turn it on first thin in the morning the heat sensor still reads 126 degrees and sometime dips down to 30 or even a negative number in seconds and then back up to 126 - that can't be right.
  • Nathanh29 May 11, 2010
    this is a common limitation with lots of apple macbooks early generation models.
    Was there a specific question you had that i can help you with?
    Nathan.
  • 143 Answers
Perhaps it is a software or firmware issue.
Make sure you have updated you mac to the latest firmware possible via software update. To get to this, click on the apple in the top left hand corner of your screen and select software update.
If that doesn't fix it, then perhaps doing a complete reinstall of the software will help, followed by updating your software using the method previously mentioned.
If this still doesn't help, then it would be a good idea to bring it into apple.
you can find a local apple reseller by calling apple on 1-800-MY-APPLE
Or you can visit an apple retail store by visiting http://www.apple.com/retail/
Hope this helps.
Nathan.
Posted on Apr 14, 2009
My 1998 lexus e300 is running hot and I noticed the cooling fans are both running but at low speed. what controls the fan speed
The PCM(computer) controls the fan speed. Low speed comes on around 200 degrees, high speed kicks on at around 225 degrees. If they come on when you first start the engine, the coolant sensor is bad. PCM is in default mode and runs the fans all the time. Since it doesn't read the 225 mark, it won't kick on the high speed. Turning on the A/C will also kick on the high speed fans. That's if your A/C works.
Jun 21, 2015 | Lexus Cars & Trucks
We refresh computers for ING and just got in around 50 M90 desktop computers. When turned on, the fans on ten of those computers run loud and never kick down. I've never experienced this issue with...
It is typical of Lenovo computers to run the fan at full-speed, when they initially are powered-on.
Then, because the fans are temperature-sensitive, they should slow-down to a much-quieter level.
Easy solution: enter BIOS SETUP, and you can configure whether this "slow-down" happens, or does not happen.
Jun 06, 2011 | Lenovo M90 SFF CORPORATE MODEL 5485E3U PC...
Thermostat temp guage goes to 220 degrees
220 degrees is normal operaing temperature for your car. The thermostat does not open until 195 degrees and the fans don't come on until 126 to 128 degrees. If it gets over 129 degrees and the fans have not turned on then the cooling fan system is the cause of the problem. (cooling fan, cooling fan temp switch, cooling fan relay, etc.)
Dec 05, 2010 | 1994 Buick Century
Pentair Master Temp Heater is not heating and reading 126
Definitely bad thermistor Pentair reps have seen this happen a lot. Lick finger and touch the two contacts where the thermistor plugs in it should fire up if it's a bad thermistor. If you do an ohm reading you'll find that the ohms do not correlate with the temperature that's displayed. I just trouble shot one and I'm getting 51.2 ohms which equates to 10 - 20 degrees Fahrenheit which is obviously not what is being displayed because it's 126 which is a common number that's displayed when a thermistor is not reading properly
Aug 28, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Mac book air - spinning wheel shows up- slow spped.
install Istat (google it, get the one that's for the menu) to monitor your cpu temps and fan speeds...when you notice they start maxing out, open up activity monitor and see what is eating up your CPU....you must have something in the background running that is causing the CPU to max out...if that's not the case then you might have a defective logic board. ------- check for start up items. thn check with activity monitor CPU and RAM usage, if its okay then check your hard drive with 3rd party programs to see if its failing. ----- Have you tried resetting some of the low level hardware?
System Management Controller (SMC):
http://support.apple.com/kb/HT1411
PRAM and NVRAM:
http://support.apple.com/kb/HT1379
Other thing to look for might be temperature (install iStat Menu and/or iStat Pro) from iSlayer.com. -----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 07, 2010 | Apple MacBook Air
Water Temp on heater reads 126 degrees F
I am not sure if you have resolved this issue, or not, but just in case. Yes, the problem is the Thermistor. This is a sensor that "reads" the incoming water temp. It is really easy to replace as well.
Jun 29, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Mackbook Fan very loud, video/flash runs slow and choppy
Generally there are a variety of reasons that can consequently cause the issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. Learn more from: http://www.howtospeedupmac.com/
Apr 13, 2009 | Apple MacBook Mac Notebook
Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Apr 10, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
My Emachine T5212 has a loud fan constantly running
sounds like a fan is going out .. with the case open can you identify which fan is making the noise?
Mar 10, 2008 | E-Machines eMachines Desktop PC
Computer fan is loud & computer running slow
There are a number of reasons might be affecting, some are dangerous while others not that serious. Learn why and how you can speed it up easily from: http://www.whyismypcsoslow.net/ hope this helps take your stress out!
Feb 09, 2008 | Dell Inspiron 9300 Notebook
Apple MacBook Mac Notebook Logo
457 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
