Question about Ricoh CL3000E Laser Printer
Color Photo Conductor Unit
I have noticed vertical lines across my printed photos. I did check the Photo Conductor Units Type 125 and found concentric circles along two of the color drums. Can this be corrected and how or is it time to replace the Color Photo Conductor. Also, what causes these rings on the drum? The printer isn?t that old. I am still on my first replacement of toner. Hope you can help. Thanks
  • Anonymous Mar 22, 2014
    how can i fix the photo conductor appairing
  • 446 Answers
The vertical line that you saw is an indication of either it is normally worn out, or something has caused the scratched, by any material ( PC drum is very sensitive to any material and can easily damaged or scratched any solid and unwanted dirt inside) see you actual meter reading. if it falls on the first thousand copies or print then it might have caused by a scratched, if it falls beyond the PM parts repalcement then there is nothing you can do but to replace this.
sometimes you can swap the colors, by the affected color use the yellow drum unit to the affected drum, the vertical would not that be obvious.
Posted on Jul 24, 2008
Lines running down the page
is it on printing or in copier mode? if in copier mode is it via feeder or on the platen glass? if via feeder see if your slit glass is clean. on top of the platen see to it that your mirrors inside are clean, if so here comes the Photo conductor units and the fuser units.
Dec 06, 2013 | Gestetner DSc525 All-In-One Laser Printer
Photo Conductor Unit Color
A Turn off the power, and then unplug the power cable.
B Open the right cover.
C Pull out the green levers on the left and right that are securing the inner
D Lift the inner cover until it stays up.
E Remove the photo conductor unit.
F Pinch the
green lever to unlock the unit.
G Pull out the photo conductor unit carefully.
H Pinch the green lever to unlock the unit.
I Pull out the photo conductor unit carefully until it stops.
J Pinch the green part to release the unit
.K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
L Take out the new photo conductor unit.
M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
Lexmark c534n printer, warning for depleted color units do not go away after replacement
The supply counter must be reset manually after a photoconductor unit is replaced. Here's an article on How to Reset the Photo Conductor (PC) Page Count After Photo Conductor Unit Replacement on C52x and C53x Series Printers. Just click on this link: Thank you for choosing Lexmark.
Jun 13, 2010 | Lexmark C534N Printer
Strange lack of color lines
These are actually called PCU ( photo conductor unit) and yes they can be required to be changed frequently at times. I work on a lot of Ricoh printers and this is a common issue.
Jul 27, 2008 | Ricoh Aficio CL2000 Laser Printer
Printing problem
Pull out the color photo conductor unit. If you see lines on any of the green drums replace the color photo conductor unit. You can also get color registration errors if the transfer unit is scrached. my first recomendation is to look at the color pcu unit and replace it if you see any lines on it. Also pull out and inspect the black pcu unit.Let me know what you find.
Jul 07, 2008 | Ricoh Aficio CL2000 Laser Printer
Not printing all text
If you blank stripes in the vertical plane, it would suggest that toner or other foreign material has got onto the laser lens. Remover the toner and photo conductor units and look for the glass panel above the laser unit. Clean this with a tissue or soft cloth. You should find this gets you away. If not then the photo conductor is the next suspect to replace.
Sep 16, 2007 | HP LaserJet 2100 Printer
Vertical streak near left edge of printouts....only affects black portion of print image
Where best to look will depend a little on the nature of the smudge. If what you're looking at is white, then you might just have a little heap of toner or paper dust on part of the LED array that paints the picture onto the photoconductor drum (look for a narrow unit that stretches full width, adjacent to the drum. Dark marks may, if you're lucky, be down to dirt on charger wires. Both respond well to cleaning with a vacuum and a soft cloth (be very gentle if cleaning the wires). I would be inclined to trust the existing photoconductor unit unless you know it's been abused (e.g. by leaving it lying around in daylight) or the coating on the drum is visibly damaged. A.
Apr 11, 2007 | Ricoh CL3000E Laser Printer
Printing lines through the color section of the document
If you have a Ricoh Laser printer you will probable have to replace the color photo conductor unit.
Oct 19, 2006 | Ricoh CL2000N Laser Printer
Ricoh CL3000E Laser Printer Logo
243 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
