Question about Olevia LT32HVM 32 in. LCD Television
When i connect my laptop to olevia tv with an HDMI cable the tv says invalid format
freetek
  • 5568 Answers
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Posted on Aug 02, 2008
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
SOURCE: invalid format when conected to laptop
i think this problem is because we cant set to the display size the tv needs... 640x350/ 720x400 in my case... sorry no solution but may help someone else.. gl
Posted on Nov 23, 2008
SOURCE: hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
Posted on Dec 24, 2008
tvtek
  • 1284 Answers
SOURCE: my olevia tv is not sensing the hdmi input right away.
HDMI has to be able to communicate with each other. In most cases the HDMI issue is with the device connected to the TV and not the TV itself. If you did firmware upgraded on the TV then the issue is with the laptop. Try the laptop on anther brand of TV and see what happens.
Posted on Jul 23, 2009
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
Invalid format on hdmi
Unplug set, HDMI, and a box if used for a while--connect the HDMI first and then power to set and or box--see if set will reboot or box.
HDMI does not like power loss, being connected or disconnected with power on etc.
Also in set menu make sure HDMI input is "available".
Apr 29, 2012 | Olevia Televison & Video
Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 11, 2010 | Olevia LT32HVM 32 in. LCD Television
"invalid input" for hdmi
This model TV has specs for DVI, VGA, component video and S-video inputs. Are you using a DVI-HDMI cable? In that case, check your cable specs. DVI-I and DVI-D (single link and dual link) are not interchangeable and I would guess you have the wrong one connected to the HDMI for your unit.
I hope this helps.
Apr 12, 2010 | Olevia LT32HVM 32 in. LCD Television
I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Dec 12, 2009 | Televison & Video
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Aug 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
My olevia tv is not sensing the hdmi input right away.
Jul 23, 2009 | Olevia LT32HVM 32 in. LCD Television
No video display,
UUUHH HHHH DUH!!ITS NOT MENT 4 PS2!!!
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Olevia LT32HVM 32 in. LCD Television Logo
762 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
