SOURCE: i have a 1989 ford F150 xlt and my reverse lighta dont work
ok i understand now the easiest thing for you to do is just get something to connect the two wires together,( like a short piece of wire ) bypassing the switch. have someone watch the reverse lights while you do this. if the lights come on then you need a switch. if not you have a bad wire or fuse/ fusible link. you can use a test light to see if you have power to the switch, one wire should have power and the other leads to the reverse lights. you can test the switch itself with a ohm meter, or continuity tester aswell if you have one. if you need more help i am here for you... dustang
Take some WD40 and open the doors and spray a liberal amount into each of the door latches. Then open and close the doors firmly several times. This will work most of the time to unstick the ajar switches.
SOURCE: 2005 FORD F150 AC blows cool/warm in front and cold n back vents
Networking Configuration
A network architecture is a set of standards for how computers are
physically connected and how signals are passed between hosts. Some typical
network architectures are described in the table below.
Network Architecture
Description
Ethernet
Ethernet is a wired networking standard and is the most common networking
architecture used in LANs (both in business and home networks).
Dial-up Modem
Dial-up networking is a common way to connect a computer (often your home
computer) to a remote network, such as the Internet or a business network. A
modem on each computer uses the phone lines to send and receive data.
DSL (Digital Subscriber Line)
DSL is a fast-growing alternative to dial-up networking to connect to the
Internet. DSL uses regular phone lines to send digital broadband signals.
ISDN (Integrated Services Digital Network)
ISDN is another alternative to traditional dial-up that can be used to
connect to the Internet or to directly communicate with another computer
connected to the ISDN network. ISDN is more common in Europe than in the U.S.
ISDN can use regular telephone wiring, but must be connected to a special ISDN
network.
Wireless
Wireless networking uses radio waves or infrared light (with the air as the
transmission medium) to send data between hosts. Wireless networks are common in
homes, businesses, airports, and hotels. Most wireless networks connect into
larger wired networks (such as LANs) which are in turn connected to the
Internet.
Communication between hosts on a network generally takes one of three
forms:
SOURCE: ford f150 xlt 4x wont engage
Soledoid at transfer case unpluged or defective on board swith..Check contacts with voltage tester at switch first... power in? power when swtch on? Go to soledoid under veh. at case
SOURCE: I installed raptor hid lights
interesting, make sure you have all the wiring appropriate and SECURE. otherwise it will not work. did the hid kit come with a relay harness? if you can send a pics of your set-up I will gladly assist you with your problem. I install hids as a job. when installing hids your not supposed to make any contact with the bulb directly against your skin, because the oils on your skin will damage the lens and less life of the bulb.
