Question about GE WBSE2090A Top Load Washer
WASHER STOPS AFTER A FEW MINUETS INTO THE WASH CYCLE
WASHER WILL STOP AFTER JUST A FEW MINUETS INTO THE WASH CYCLE. IF I WAIT A WHILE OPEN AND SHUT THE LID THEN RESTART IT DOES THE SAME THING.
  • DEJOEGUY Sep 12, 2007
    IT IS A GE MODELWBSE2090A0WW. THANK YOU
  • DEJOEGUY Sep 14, 2007
    the machine fills ok then begins to agitate for a couple of min. then stops
Yes i am right then, it sounds like a heater problem, check element for open circuit, or a wire off maybe, it is also possible the circuit goes through a thermostat, that can be checked if element is ok, thank you
Posted on Sep 16, 2007
  • 209 Answers
You didn't say if the machine had filled up with water and stopped after that, if that is so then the place to check first is the heater element for open circuit, this will be located at the bottom end of the drum area, remove plug before testing, work safe, hope i have helped a little, if the machine has not finished filling check the water supply first then the water solenoids. hope i have helped, if so rate me please
Posted on Sep 14, 2007
Wash and spin cycles timing is off
a blockage in the pump could make this happen,.......check the pump for a bockage......
cheers
Oct 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Have a Sears 110 topload washer, it fills, agitates for appx 10 seconds, stops,wait for a few minutes, agitates again for a few seconds and stops. ??
this sounds ilke its in a delicate cycle or fabric care cycle...did you try putting this in normal or regular wash are the speed selectors set to fast/fast...let me know if this does not help...
Jan 23, 2011 | Kenmore Washing Machines
My washer stops in the rinse cycle and sometimes in the begining of the wash cycle again
Not exactly easy to determine. Must check a few things first. 1) Does the timer stop at exactly the same places everytime when it stops? Make a mark at the place it stops and restart the program a few times. When it does stop, note if it is always at those marked positions. If so, the timer needs to be replaced. If the stopping positions on the timer are in the middle of washing and especially the spin, then the motor is defective.(the internal overload/overtemp) protection is activated,.
Aug 22, 2010 | Admiral 32 cu. ft. Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WBSE2090A Top Load Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
