WHERE IS THE FUSE LOCATED ON THE MOTHERBOARD - Computers & Internet
  • Dick
    Dick May 11, 2010
    Most motherboards don't have one. If you post your make and model we can tell you for sure.
  • 90 Answers
U cant change it urself dear. it depends on each motherboard
Posted on Apr 14, 2009
Where is the fuse located on an HP550 motherboard
depends wich one an youl need an realy good specialist to do that (and you need an schematic to see where is the one that is giving you problems )the comp is starting ? the comp stops when ,there are not only one fuse ,depend of the situation.
Jun 22, 2013 | Computers & Internet
Does my lg Wm3360hvca have a fuse?
MORE THAN LIKELY IT HAS A FUSE SOMEWHERE DO U HAVE THE SCHEMATIC?
IN SOME INSTANCES THE FUSE CAN BE ON OR NEAR THE MOTOR, BUT USUALLY THEY ARE LOCATED IN THE PANEL AREA
Mar 22, 2013 | LG WM3360HVCA Steam Front Load 3.9 cu ft...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I had a static discharge from my finger to the USB port on the front of my PC. The system locked up, so I turned it off and not it will not turn back on. The pc is one I put together and it has a ASUS P5W...
    Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
    May 08, 2011 | ASUS P5W DH Deluxe Motherboard
    I suspect the motherboard's fuse has blown
    some have them and some do not have fuses. If you are looking at yours and not one is found you must be looking at an Emachine brand motherboard for they never did installed one to save on cost
    Jul 11, 2010 | Intel Motherboard
    Where is the motherboard fuse located on a acer aspire 5920 ? thanks
    i do not beleave there is one i have an acer 5315 and no mother board fuse.thats why we use surge protectors.i have my manual here and i see NO fuses.
    Oct 09, 2009 | Acer Aspire 5920-6727 Notebook
    Acer extensa 4620 no power or video
    You more then likely fried the motherboard with that move. There is no internal fuse that you are able to replace or reset. Replace the motherboard, nothing else that can really be said but that.
    Dec 08, 2008 | Acer Extensa 4620 Notebook
    Nothing at all
    I had a similar problem, 80% battery phone randomly shut itself off and would not start again. no lights if I plugged in charger or anything to indicate phone was getting juice. Found a diagram of the motherboard, located the fuse and operated on my phone. If I touched the 2 ends of the fuse with tweezers and plug in cord, got the red light with no battery. This indicated fuse bad. put a little trail of sodder to connect the 2 ends of fuse and put battery in and presto, I now have working phone with no power fuse. Could burn up some day but was going to be trashed anyway as out of warranty.
    May 29, 2008 | AT&T 8525 Smartphone
    Where is this fuse located on the LG refrigerator is displaying a ER DH code error
    Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
    Jan 02, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
    No power (orange) charge light
    Hi there, I am assuming that it was working ok until you tried to charge it then?? I have come across this problem before and you are right about the fuse, there is a fuse on the charge/power circuit that is located in the very top right hand corner of the motherboard, next to where the black power lead attaches to the motherboard - if you repair or bridge that fuse then it will work fine assuming that like I said at the begining it was working before you put the wrong charger in. If you cannot repair that fuse then the console will work fine if you can charge the battery without using that PSP (i.e. another psp or third party external charger) as there is no fuse on the battery circuit as there would not be a surge in power unlike the mains circuit. If you need more information or if this reply is not clear then let me know and I'll get an image of the fuse you need to repair.
    Aug 30, 2007 | Sony PlayStation Portable (PSP) Console
    Computers & Internet Logo
    158 people viewed this question
    David Payne
    David Payne
