Question about ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Asus motherboard A8V doesn´t works at ATA6-133Mhz
I have a motheboard asus A8V with a processor type athlon64-3000+. So, I´ve got a Samsung IDE HD SP1604N that was supposed to work at ATA6-133. Instead of this, this motherboard only let this HD work at ATA5-100. My SO is windows xp sp3 and i have also made all the drivers updates, including the ones for VIA chipset. I´ve made the BIOS update too. I don´t know what to do now and really preciate any help.
Thanks!
  • fifaplayerbr Apr 14, 2009
    The solution is:
    "http://www.samsung.com/global/business/hdd/support/utilities/Support_HUTIL.html"
    Neither Windows XP nor Asus BIOS can change the UDMA and the "automatic acoustic management" to higher options without using this program made by samsung (HUTIL.EXE). It should be run in a bootable pendrive, in DOS mode. They only allow to choose lower options.
    Thanks for the help and the quickness to aswer. I appreciate this a lot and hope my solution could help someone in future.
  • Dick
    Dick May 11, 2010
    ATA-6 is only UltraDMA/100. 133 is ATA-7. Even 7 has been around for years and your motherboard's BIOS should support it. All I can think of is possibly you are using an older cable or a damaged cable? The BIOS setting should be set to Auto, NOT DMA or PIO. If you have multiple hard drives in the system I prefer to put one hard drive on each IDE channel so if you're pasing data to or from both drives at once you are not passing it all through the same cable.
    Problem Solver:
  • 19 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
alkllklju43
Posted on Sep 08, 2009
I have Asus A8V-MX motherboard ,chipset via K8M400. processor is Amd athlon. i am not able to get the video driver(vga) for above specification.OS: Windows XP. please help meto overcome this problem. and...
you can download the drivers from the below link
http://www.driverstock.com/ASUS-A8V-MX-driver-download/6-9-10210-81422/index.html
VIA K8M890 VGA Driver (32bit).
VIA/S3G UniChrome Family Display Driver V6.14.10.0227 for Windows 2000/XP/2003(WHQL)
Jul 25, 2011 | ASUS A8V-MX Motherboard
I have ASUS A8V-VM Motherboard a8v uayvz with amd 3700, what upgrades ave available ?
Hi Cheqel,
Here is the weblink which has all the updated version software for your motherboard.
http://usa.asus.com/Motherboards/AMD_Socket_939/A8VVM_SE/#download
This will be great.
Jul 06, 2011 | ASUS A8V-VM Motherboard
I have asus a8v-mx motherboard. processor : amd athlon processor. i need a motherboard video driver for desktop system.
Find out what video/graphics card you have then just go to the website and download it from there. If you need more information let me know.
Thanks
Jason
Nov 02, 2010 | ASUS A8V-MX Motherboard
I have missed the motherboard Cd for my A8V-VM SE with AMD processors so which are the drivers are to be loaded so as to detect the sound card and VGA
Download the drivers you need from Asus;
http://www.asus.com/Search.aspx?SearchKey=A8V-VM%20SE
Realtek Audio Driver and VIA Onboard VGA Driver.
Once the site above loads you'll need to click on the drop down menu and click on you're operating system.
Thats it!
Good luck
Mike
May 13, 2010 | ASUS A8V-VM Motherboard
Can I use a Amd athlon 64x2 dual core processor 4200+ 2.2 ghz on my A8V deluxe motherboard . socket 939
Yes, according to the Asus website specifications on the A8V Deluxe you are able to run the CPU. You just have to make sure that the CPU you buy is for Socket 939 and not AM2.
Please rate!
Cheers
Oct 04, 2009 | ASUS A8V Deluxe Motherboard
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS A8V-VM Motherboard
DDR2 with ASUS A8V-MX motherboard
This motherboard supports AMD 939 pin Athlon 64 FX/ Athlon 64 processors with 1MB, 512 KB L2 cache which is based on 64 bit architecture. It features 1600 MT/s HyperTransport Bus, dual-channel unbuffered DDR400 memory support and AMD cooling Technology. So you should be able to use the RAM as long as it falls into the above specs. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | ASUS A8V-MX Motherboard
Missing Motherboard cd
i have no cd of driver plz.send asus a8v-mx driver.
processor-AMD Athlon 64
Oct 31, 2008 | ASUS A8V-MX Motherboard
Hitachi 400GB internl drive not seen.
Initially, pls :
  • check/replace IDE cable used;
  • check power connector;
  • verify master/slave jumper setting;
  • reset CMOS/BIOS to default;
  • change motherboard IDE connection from IDE1 to IDE2 or vice versa;
  • try as a standalone, temporarily remove any other IDE device such as the DVD/CD.
If all else fails and thee HDD works/checks OK in other machines, you may need to update the BIOS of the Asus A8V deluxe. Pls start here. Click on "DOWNLOAD", on the :Input Model to Search" type A8V, in Select Category, choose BIOS, click on Search Info button, follow on screen instructions
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
ASUS A8V-VM SE (MB-A8VVMSE) Motherboard Logo
207 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
