Question about iLO 2600 Television
Dish network box hookup question.
Hello, I recently mounted my Ilo 26" HD LCD tv on the wall in my bedroom. It had previously been in my living room and was hooked up directly to my dishnetwork box using the red,green & blue wires that were supplied when I ordered the satellite system. My satellite box is a duel tuner system, so I figured I could just hang the tv and screw in the coaxial cable that I had them run into my bedroom at the time of installation. When I went to attach the cable wire, I noticed that the female "attenna in" input is not threaded, therefore it is not compatible with my existing coaxial cable wire. My question is, since I do not have a satellite box in my bedroom, can I just change the end of the cable wire or will I need to have a whole new wire run from my dish to the bedroom?
  • 752 Answers
Are you sure that the antenna in isn't threaded? You may be looking at the wrong jack... All antenna inputs are threaded co-axial "F" connectors. If you ARE sure, could you post a pic of the back panel?
Posted on Sep 12, 2007
SOURCE:
I have a hitachi 26ld660c tv that is wall mounted, I need to purchase the table mounts and stand can you help
If you live here in the Philippines, visit CDRKing they have wall mount gadgets. or try on Ebay for any other option of wall mounted bracket.
Sep 23, 2011 | Hitachi 26LD6600 26 in. HD-Ready LCD...
I cant connect my dish satalite to my ILO telivision, should it be connected to the ATV port or the DTV port.
If you satellite is HD don't connect it to either port, Use an HDMI or component (5 wire cable) so as to receive high def signals. If you must uase channel 3, You want the ATV input. On channel 3 YOU WILL NOT RECEIVE HD PROGRAMMING> check your hookup guide from Dish network.
Jul 09, 2011 | iLO Televison & Video
Remote code for 26" LCD Dynex tv
Remote code for who? Dish network? Comcast?
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
Jun 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
What are the connections to add a Home theater system to Dynex 26 in and Dish DVR network box
Hi my nameis Mike Houston of DISH Network and I see where you want to connect a HomeTheater system to the Dynex TV. Do to different systems are different and wedon't know the specific model of the Home Theater unit you are using the bestthing is to check your TV manual for best connections, if you have any questionsplease e-mail me at [email protected]
Jan 05, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
What is the code for dish network remote 21.0 IR/UHF PRO?
Hello!!! Your post is not clear on if you need to program the remote to the receiver or the tv, but here are steps to program to both. Just follow the link provided below, and you will be good to go!!!!
Becki Barned
Dec 09, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have a ILO-26 LCD tv and no code for my Dish Network remote
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotes/TechRemo2wayCode.shtml
Jun 14, 2009 | DISH Network ViP 211 DTV Receiver
Universal remote
only a uhf remote will work from that location, you will probably need to get a dish network 6.0 or 6.3 remote
Jul 04, 2008 | DISH Network 322 DTV Receiver
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Televison & Video Logo
285 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
