Question about HP PSC 2410 All-In-One InkJet Printer
Hp psc 2310 is "stuck"
My hp psc2310 was working fine until recently. The problem has been occurring intermittently over past month or so, but I could usually fix by simply unplugging power and reconnecting. (Coincidentally, I installed Vista around about the same time). Now nothing seems to help and I can't print, or scan or copy.
When I turn the printer on, display says "Initialising" then machine makes a clunking sound as if print cartridges are stuck and aren't moving . This noise goes on for approx 1 - 2 minutes then message says" Scanner failure - turn power off".
I have tried cleaning all the bits I can get to, partial reset and various versions of a full reset but nothing seems to be working.
Can anyone help me please ?
  • 2 more comments
  • surridgeprop Apr 15, 2009
    I have been having the same problem for over nine months. I turn the machine on and for about 1 min you get this loud clunking sound. Then that stops and the "egg-timer" comes up in the window and that's it. None of the controls work and the machine freezes. I originally managed to get round this by unplugging and plugging it back in several times, and eventually it worked. Once it was working, I decided to never turn it off, so it's been ok (although very bad for the environment, as it's wasting electricity). However, I was doing some scanning the other day, and on the third scan the loud clunking noise suddenly started, and now the machine is well and truly stuck.
    Any ideas please...I certainly won't buy HP again after this experience.
  • Anonymous Apr 25, 2009
    HP psc2310 cannot scan and call HPdirector
  • Wendyma May 09, 2009
    tried this cleaning process.....didn't work
  • kesammut May 13, 2009
    Thanks everyone - I cleaned the bottom of the glass as a last resort . It was a bit fiddly but amazingly it worked first go!
    I don't understand why it worked but I am back in action - at least for now. Thanx everyone for your help.
This has been solved in the fixyourownprinter.com forum. Clean the bottom of the scanner glass. You have to take a bit of it apart but it's not hard with the help of this HP site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553775&cc=us&lc=en&dlc=en&product=303753&dlc=en&lang=en
Good luck.
Posted on Apr 29, 2009
I had the same problem and started the process to clean the glass...removing the cover and the panel...
Turns out I didn't have the correct screwdriver to remove the screws to get to the glass. In the meantime I noticed that one of the cables under the "control" panel wasn't connected when I removed the panel. I connected it and put the panel and cover back until I could get the correct screwdriver. When I turned on the printer, it started working correctly - no noise or hour glass! So it was a cable that had come loose.
Posted on May 20, 2013
Toyota Prado 2009 diesel intermittently stalls when idlying once heated up
SOUNDS LIKE THE FIRST STAGES OF AN ELECTRIC FUEL PUMP FAILING. THEY ARE NOTORIOUS FOR THESE TYPES OF SYMPTOMS. THE LOW PRESSURE AT THE TRAFFIC LIGHT RESULTS IN THE STALL, BUT AS LONG AS ITS UNDER DEMAND IT WILL FUNCTION OK UNTIL IT QQUITS. HAVE A PRESSURE CHECK DONE ON THE FUEL PUMP
Nov 04, 2012 | Toyota Cars & Trucks
HP PSC 2310 The printer is working but not the scanner - why
please tell me details
I hope your printer driver is not install properly
or your windows is problem by virus
tell me can you take any photocopy.
Oct 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
My HP PSC 950 prints anything from the Inernet too
Browser printing option is set to print small you need to check that and make sure you using landscape.. There should be no other reason why so check those landscaping options- thanks and please rate acordenly anything above a thanks for trying would be pleasureable..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 15, 2009 | HP PSC 950 All-In-One InkJet Printer
Remove and check cartridge
If you already changed the cartridges for new ones, there should be a problem with the printer's carriage.
You need to take it to a repair store, but I advice you to buy a new one, because the price you will pay for the repair should be the same or more than what you pay for a new printer.
Nov 26, 2008 | HP PSC 2210 All-In-One InkJet Printer
Check Carteidge Light Come Out without any change on hardware
sometimes you have to look through the settings and allign the cartidges.....check the options on the litle screen on the printer....itll be in settings....let me know what hapens
Oct 02, 2008 | HP PSC 1350 All-In-One Thermal Printer
Intermittent connectivity
Check to see if you are losing the DSL or Internet light on the modem when you lose your onnection. If so, then check with your IP provider, that may be the problem.
Apr 11, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
PC power resets w/ HP PSC 1210 plugged in
one of these updates causes a conflict more than likely a microsoft hotfix, try using a different usb port and unplug and plug printer back in
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
1,122 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
