Question about Hitachi P42H401 42 in. Plasma HDTV
Video settings wondering if i could get optimum settings for this tv.
  • 752 Answers
There really is no generic "Optimum Settings"... It basically comes down to what looks good to YOU. If you really want to get it as close to the original source recording as possible, get a movie like "Fantasia 2000" that has the THX video optimizer. The disc has a series of tests and procedures to help you configure the video settings for the most accurate picture.
Posted on Sep 13, 2007
SOURCE:
Optimum remote control item no.323461.set up code no for philips tv English language
Hi Billie-Jo, can you post a picture of the remote...looks like Optimum has different Phillips code based on model
Oct 08, 2018 | Philips Televison & Video
Optimum remote only works for tv settings not cable box
Cable boxes don't have a universal remote. They have to be different than the television remotes and they are make and model specific.
Jul 13, 2018 | Televison & Video
I HAVE A JVC T.V.MODEL#JLC47BC3002 I HAVE OPTIMUM SERVICE NO VOLUME CONTROL ON THE REMOTE AND TV DOESN,T SHUT OFF THE TV, BUT SHUTS OFF THE CABLE RECEIVER
Well, if this is not the original remote then it may not be set to the right number to operate all the functions of the TV. If it is the original remote then either it or the set have a problem. Sounds like a remote not set up correctly problem to me tho.
Apr 28, 2017 | JVC Televison & Video
Hello, My winXP cannot recognize monitor Asus VH232T - windows suggests 4:3 resolutions only. Can you please advise where can I download the monitor driver? Video card is ATI RADEON XPRESS 200 Thank...
Hi
Monitors do not generally require drivers. The .inf drivers to run almost all monitors are already in Windows.
The problem here is in the settings of the graphics card.
Many users aim for Maximum resolution, when what they should aim for is Optimum resolution, balancing the RAM, CPU, GPU, GRAM and Monitor''s resources in the most efficient and effective way.
Keeping the relevant software updated also has an impact on graphics performance (grpahics Card Drivers, Java, Flash, DirectX, Video Codecs, etc.)
If the video resolution is set too high (or too low), beyond the graphics capabilities of the monitor, on reboot, the monitor will be unable to resolve the image.
The simplest solution would be to use a different monitor to adjust the video resolution, shut down then test the preferred monitor again.
Right Click on desktop>Properties>Settings then use the slider scale to adjust resolution, then Apply, Yes on the optimum setting, them OK.
Find the optimum setting in XP with your graphics card for this monitor and you should be fine.
Hope this helps.
Aug 02, 2011 | ASUS VH232H 23" Monitor
Not optimum mode
It is complaining because your PC video resolution is not set to the monitor native resolution, which is 1280 x 1024 @60Hz. Try setting your PC resolution.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
Optimizing image sharpness of 32" Grinding TV model GR320HS
Try Googling (Grundig)(GR320HS)(manual) without parns. Note spelling of Grundig.
Feb 07, 2018 | Televison & Video
Optimum settings for 32LG3000
I cannot give much of a solution based on the amount of detail you have given, but I will try.
Generally speaking most TV factory settings are set too high through the brightness and contrast controls, and this is probably the problem you're describing. I advise adjusting the brightness lower, and the contrast slightly higher.
Try watching a DVD and pausing a particular scene which has lots of dark gray's and white's and then try to figure out the optimum setting.
Apr 19, 2009 | LG 32LG30 32 in. LCD HDTV
TV PANASONIC-SERVICE MENU
press "MUTE" on remote control and "V" on TV set, when the sharpness is set on minimum and programme position is on 99.
5. Horizontal Shift H-CTR 31 Optimum setting. 6. Horizontal parallelogram H-PAR 034 {034} [-] Optimum setting. 7. Horizontal bow H-BOW 031 {031} [-] Optimum setting.
Sep 22, 2008 | Televison & Video
I have a great picture ..but wondered what others setting users found to be optimum... have a 42 panasonic 80u
To get the opt out pitcture is first your signal & your happy with that. So, I would contact a local store or service center that does calibrations. They will go into your service menu & adjust your tv to it's max. Enjoy...hd.
Apr 02, 2008 | Televison & Video
Hitachi P42H401 42 in. Plasma HDTV Logo
158 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
