Question about Zenith P42W46X 42 in. Plasma EDTV
Picture is snowy/dark
Tv is approx. 3 years old. after shutting off, turned back on and the picture will not come in clear. It is dark and snowy. We have tried disconnecting/reconnecting all of the cables and hooked a different tv up to the outside cable line, other tv has great picture.
  • Anonymous Mar 20, 2014
    I hit the auto tune on my tv and only have the snowy screen how do i get my picture back
Update: Well, we ended up calling the repair man and we had a bad Y-sustain board and also a bad Z-sustain board. According to the guy who fixed it, it was due to over use of the TV and using main power button instead of shutting off through the cable remote. 650.00 later and a few weeks later, we now have a fixed plasma. No real suggestions on how to get more life out of the new boards.
Posted on Oct 08, 2007
SOURCE:
LG flip phone will not turn on. LG logo lights up screen for approx 5 seconds, then goes dark again for approx same amt of time then repeats. Tried taking out battery and putting it back.
You should try a factory reset, just google the make and model for instructions to do the factory reset, if that doesn't clear the issue you need a new phone.
Sep 28, 2016 | LG Cell Phones
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
13 TO 14 YEAR OLD SANYO TV SHOULD I GET IT FIXED
You try to play the video tape or DVD. If picture still snowy, the picture tube is getting old. Buy a new one, do not repair it will cost almost a new set.
Aug 12, 2009 | Acer Aspire One AOA110-1588 Notebook
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Unable to retrieve picture on TV
when the screen becomes snowy, it means that something in the cable box is being overheated. what you should do is take a small desk fan and hold it beside the cable box. this has happened many times when my family has played on their xbox 360, and the desk fan solved this problem. i hope that this helps!
Jun 12, 2009 | Televison & Video
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
[email protected]
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Snowy picture
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
Toshiba tp50f60
1. Check the TV's horizontal and vertical hold. 2. If there is a VCR connected: Shut off the VCR. If the problem clears up, the VCR is not properly ?fine-tuned.? Turn the VCR on and troubleshoot the VCR problems. 3. If a converter is connected to your TV and VCR: The VCR needs to be on channel 4. VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. 4. Check the fine-tuning of your TV. good luck :-)
Jan 11, 2006 | Toshiba TP50G60 50" Rear Projection...
Zenith P42W46X 42 in. Plasma EDTV Logo
260 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
