Have a JVC LCD LTZ26SX5 56" TV, 3 years old which hasnt seen a lot of use. Now a reddy pink vertical stripe from top to bottom appears on left hand side, approx 3 mil thick and placed 10 cm fom left hand edge of screen. Many Thanks
  • btossol Apr 14, 2009
    Thanks, please note my TV is a standard LCD flat screen TV, not a rear projection or 'projection' TV. Just checking that we are talking about same thing.
    Cheers
  • btossol Apr 15, 2009
    External Digi Set Top box attached to this TV, but line still appears even when box unplugged. No other devices near. Played with colour schemes and aspects with no change.
  • 10,594 Answers
Pink vertical strip in LCD TV shows problem either with LCD Controller Board or LCD Panel itself.
LCD controller board is not so costly and that can affordable replacement and LCD panel is high cost item and some time new TV is better option.
Click Shop Jimmy or call 1-877-881-6492 for part/ board price and stock inquery.
Thanks.
Posted on Apr 15, 2009
    Brigadier General:
  • 3,917 Answers
Is there any electrical gadgets kept arround the TV which might be causing the color strips. By electrical gadgest I mean high capacity sound box/ mobile set or micro ovens.
Also work with the color schemes to find if the screen is centrally positioned.
Thanks
Posted on Apr 14, 2009
    Scholar:
  • 123 Answers
Need to replace the vertical output IC. Thats usually the problem when ever you have a line running from side to side across the screen in the middle
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Transparent blue band
THIS IS MOST LIKELY TERMINAL. YOU NEED A NEW PANNEL. YOU CAN TRY TO TAKE OFF THE BACK COVER AND RESEAT ALL THE RIBBON CABLES THAT GO TO THE PANNEL. IF THIS DOSEN'T FIX IT, BUY A NEW TV.
Apr 23, 2008 | Philips 17PF9946 17 in. HDTV-Ready LCD...
Lcd tv picture,on start up thin coloured vertical lines appear then a black fog appears right hand corner and eventually covers entire screen,image of programme can be seen underneath.Eventually picture...
is this a rear projection tv? a table top one? how old is it because if it's over a few years old, then it sounds as if the bulb may be going out but without having more info, it's hard to give an accurate advice.. please let me know if this helps..
Feb 27, 2008 | Zenith D60WLCD 60" Rear Projection...
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
