Question about Minolta Maxxum HTsi Plus 35mm SLR Camera
Film won't adanvce
I purchased the camera used, and put in new batteries. When I first turned the camera on, I got some numbers in the window, then an "err". Now, the film will not advance and the err won't go away. Also, I'm not finding the reset button.
  • 49 Answers
Needs new batteries, or the film isn't loaded properly. Check the battery area for rust too and clean the contacts gently with a pencil eraser.
Posted on Sep 14, 2007
SOURCE:
We ran the battery down when we were filming when we put in a new charged battery it won't turn on anymore
Possible that the new battery voltage/current is low. If this is the recharge-able type , as you have not mentioned then have it charged for a long time. Check the voltage on the battery and then try. If the camera does not work then it is possible that some errors have crept into the control board. leve the camera without battery for few hours and then try. if not you must take opinion from the service center.
Jul 06, 2011 | Cameras
I have an old Canon 105 zoom sure shot. I want to get the old film out but the battery is dead. I don't want to purchase a new battery. How can I accomplish this? Thank you [email protected]
If you have a changing bag, you can put the camera inside, open the back, remove the film, and rewind it by hand. You can also do the same in a darkroom (a photographic darkroom, not just a dark room). A good camera store can do it, though you'll probably also have to have the film processed there.
If you have any plans to use the camera in the future, you may as well invest in a battery now. You can take the battery out of the camera and set it aside to preserve the charge.
Apr 21, 2011 | Canon Sure Shot 105 Zoom S 35mm Point and...
I have a 35mm nikon camera. I've changed the batteries but the film won't load. how can i load the film?
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
Aug 06, 2010 | Nikon F80 35mm Film Camera
What type of battery & film
go here http://www.dealtime.com/xPO-Fuji-Nexia-Q1 and it will tell you the battery and film type for this camera, I believe it is 24mm film so the one you got should be fine and the batteries are 1 x 3V Lithium Battery (CR-2)
Hope this helps
Jan 13, 2009 | Fuji Nexia Q1 APS Point and Shoot Camera
I can't get my fuji discovery 1000 zoom to read film
A camera is for recording images onto film, not reading the film.
Jul 18, 2017 | Fuji Discovery 1000 35mm Point and Shoot...
Film advance
throw it away, its already old, buy new ones a pentax g40, its a computer compatible.
Feb 28, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
My minolta sightseen camera wont take pictures?
The blinking zero would indicate that the film has not loaded but the cartridge is in place. The camera won't do anything when this occurs. Try opening the film door and load the roll again
Jan 14, 2008 | Photography
Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Oct 22, 2007 | Pentax ZX-50 35mm SLR Camera
Turn it on
Actually, you don't have to "turn on" the Vivitar V3800N. Just be sure it has working batteries in it (takes two small alkaline button cells, unscrew the cover on the bottom with a coin--put new cells into the holder with the + side up). If the batteries are working, when you press the shutter button halfway down, you should see an LED light up in the right side of the viewfinder. This is the readout for the exposure meter: a red + indicates overexposure, red - is underexposure, a green dot means you've got the exposure correctly set. You just change the shutter and aperture settings until you get the green light, then shoot. When you load film, you also need to set the ISO film speed setting. Pull up on the outside ring of the shutter speed dial and turn it until the number in the window is the same as the ISO number on the film you are using. The batteries, by the way, only power the exposure meter. The shutter is fully mechanical (just like in the good old days), so you can use the camera without batteries if you have a separate exposure meter, or if you can estimate exposure. Film loading is about like any other 35mm manual camera: pull up on the rewind knob to open the back; insert the new cassette of film on the left and pull the film leader out a couple inches and hook the film to the takeup reel on the right. Move the film advance lever a bit to be sure the film is firmly hooked onto the reel, then close the back. Wind and shoot three shots to get the exposed film leader out of the way, and then start shooting. When the film is finished, press in the rewind button on the bottom of the camera and rewind the film into the cassette before opening the back of the camera. Good luck--these are pretty good little cameras. We buy a lot of them for the photography program where I teach, and I've only ever had one with a problem (meter was bad). The lenses are quite good, and they are "K-mount," which means that any Pentax bayonet lens, and gazillions of others with this mount, will all fit. --Michael R. Sawdey
Sep 03, 2007 | Vivitar V3800N Zoom 35mm SLR Camera
Minolta Maxxum HTsi Plus 35mm SLR Camera Logo
108 people viewed this question
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
