Question about Canon i850 InkJet Photo Printer
Cannon i850 printer. Power went out in the middle of a job.
The paper jammed and the power went out or visa versa. Either way I can't get the power back on. Is there a restart button or some other way to get the printer going again? I checked the power connections they are solid.
  • marv413 Apr 24, 2009
    Were is the fuse located?
  • 661 Answers
Have you checked you are getting juice into your printer.... possibly you have a blown fuse, check cables as that may be your problem
Posted on Apr 24, 2009
3 FLASHES POWER LIGHT COMMUNICATION PROBLEM
Power light blinks slowly
The printer is out of paper in the middle of a print job.
Load more paper. See "Loading paper" on page 20.
Power light blinks rapidly
There is a paper jam.
Clear the paper jam.
Aug 13, 2012 | Lexmark Z1300 InkJet Photo Printer
Canon mx410 paper jam error
For me on my Cannon MX410 with a "paper Jam" light displayed this WORKED!! The absolute BIZZARE thing was after I went and through the described procedure above and rebooted and tried to print the 1st page that came out had a "crushed" ****-roach on the 1st page! So I didn't have a paper jam,...but a
ROACH Jam. :) I told my wife, Humm pest service not workin I guess! It errored out again, but simply unpluggingUSB and power cord (not the steps described for the Print Spooler) it prints fine. SO saved me buying a new printer which was just 6 mos. OLD and FINE by me! So THX, Vikram Kumar Thumu!
Jan 28, 2012 | Canon Pixma MX410 All-In-One Printer
I have a dell 948 all in one printer, clear paper jam then press check. There is no paper jam. I have follow instruction and site recommendation, ran printer software, problem still exist, please help
This is a known issue with Dell all in ones.
It's a problem with the power supply inside the unit.
If you were in the middle of a print job, though, and it jammed, do recheck as I've been caught out
with a paper jam where a tiny partical of paper was doing the jam. Look carefully before contacting Dell support.
Dec 31, 2010 | Dell 948 All-In-One InkJet Printer
Cannon MP370, says clear paper jam, none seen
i know that happens to me check that everything it as it sould and resated
Dec 29, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
My IP 5000 Cannon printer says I have a paper jam but
Under the circumstances go to control and click on printer. Clear all the printing jobs. Switch off the printer and the computer. Wait for sometime and restart the computer and the printer. This should clear your problem.
Dec 20, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
PAPER JAM. NO PAPER IN MACHINE BUT STILL GET PAPER JAM SIGNAL. OCCURRED IN MIDDLE OF PRINTING PG 2 OF 2 PG JOB. I CAREFULLY REMOVED THE HALF-PRINTED SHEET, PRESSED "OK" AND IMMEDIATELY GOT "PAPER JAM"...
the first step you should do is.
> unplug the power cable from the printer and then plug it back in.
> clean all the rollers which are there.. front rollers, adf rollers.. rollers at the back ..
> if does not work then. perform a reset.
( unplug the power cable from the printer while the printer is on. and after that press and hold the 6 and the # key on the printer. while holding and pressing down these keys plug in the power cable and wait fr 20 secs and then release the buttons.. )
this is a reset..
after this reset it will take few minutes to initialize.
These steps will possibly resolve the issue.. if not i must suggest to to get a new printer..
Oct 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Cannon Canon i960 Photo Printer
Canon i850 receives message that there is a paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 22, 2009 | Canon i850 InkJet Photo Printer
381 Paper Jam Error
I had to remove every toner cartridge and drum. I found the paper under the second to last drum.
Jan 22, 2008 | OKI C5500n Printer
Canon i850 InkJet Photo Printer Logo
79 people viewed this question
old marine
old marine
