Question about Troy Garden
Troy-bilt s-p mower wont restart when hot, only when cold.
I have a four year old troy-bilt self-propelled mower with a 7 hp B&S engine. It is a fresh start model with the primer pump at the carb. For most of the last year and so far this year, I have had the same problem. I have taken it to a repair shop twice with this problem and they havent identified or fixed it. My mower will start great when it is cold. Once the mower gets hot and I stop it to empty the bag it will not restart. I pull and pull and no offers of starting. Sometimes I even prime the pump again and no help. If I let it cool down for 30 minutes or so, it will start again on the first or second pull. I have run carb cleaner through it and cleaned the tank and line to the carb, but found nothing. The plug is fresh and the air cleaner is clean. I am ready to ''tank'' this mover and get me something else (like a honda powered mower). Any ideas on what to try...I am REALLY sick of pulling and pulling and pulling......
5 Suggested Answers
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
moretons
  • 155 Answers
SOURCE: I have a Troy-Bilt Mower - Model 834. It has a
sounds like the throttle cable has slipped on the side of the engine if they dont pull the choke all the way on they wont start too well. one way to find out is take your air cleaner and outer cover off so you can see in the front of the carby the put your throttle on start/choke position the choke butterfly should be closed if not check your cable.
Posted on Jul 27, 2009
witserv
  • 144 Answers
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Posted on Jun 14, 2010
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower cable won't pull to start engine. troy bilt 210 self propelled mower.
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Apr 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
418 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
