Question about Car Audio & Video
Wht wait oil it takes and if it takes smething else
I jst bought ths 6.0 hrse power rotiller bolin it has 2 places to put oil and i dnt know wht goes in other oil spot
    Problem Solver:
  • 6 Answers
You might wanna try going to the place you bought it from to ask or you can even go online to the manufacturing website and it should tell ya.
Posted on Apr 14, 2009
I help an fynd wth hs whts ap digits...gave my numba,bt nw my numba is no lnger alowd to use whats ap service...dnt knw wht too do....nd i need ths numba.....0840595152 plz
For problems with your phone number contact you phone provider. Or Perhaos you forgot to Paypal a Bill? For problems with apps or programs, contact the firm you bought it.
Mar 20, 2015 | Cell Phones
Have a chrysler 300 with a 3.5 litre engine. steam
Sounds like a gasket yes. If the head is aluminum it could be warped, or bock could be cracked. Either way, water in exhaust system is not a good sign. Check the oil. If there are bubbles, foam, or anything but oil, then you know it's mixing someplace.
Sep 14, 2013 | 2001 Chrysler 300M
I have a 92 Kawasaki 250 just got it but the thing is I Dnt know wht kind of oil to use for it
You must be more specific about exactly what model 250 you have. ie; KX, Ninja, KLR???? Also in which area does this oil go as in the KX, it would use a 2cycle oil in the gasoline premix and a transmission oil in the gearbox.
Jan 14, 2013 | Motorcycles
Where do i put the transmission oil for puegeot 806 lx auto date of reg 13/2/2001 have no manuel but i dnt know where the automatic tranmission fluid goes plz can you help and is that the right oil the...
First of all we need to know if the vehicle is automatic or manuel? if its automatic then you can ad oil through the ****** dip stick hole and if the vehicle is manuel gears then there is diffrent oil and a diffrent place to put the oil in. Donot put gear oil in power steering.
Sep 08, 2011 | Peugeot Liberte Cars & Trucks
Hi ive jst bought a 2007 ktm 250 sxf an im not sure how much oil i have to put in it wen i change it?
Most MX bikes take about 1 liter to 1100mm if you dumping the oil filter as well but ring your local KTM dealer to confirm
May 21, 2011 | KTM 250 SX-F Motorcycles
I have a Pony 1100 series Rotiller that takes off very fast and hard to control (I'm not a small guy either)even after setting the throttle at the lower speed and adjusting to depth highth. The ground I...
The reason that it does this, is your tiller is too light. There isn't enough weight to make the tiller dig without lifting the tires up and running on the tines. MTD owns troy-bilt now, and has made them light and cheap like the rest of the MTD lines. Your best bet is to add additional weight to the front, back, and you can even add weight to the tires if you wish. The easiest way is a rock or piece of concrete on top of the handle where the handle meets the engine. I mixed up concrete and cast it onto the front guard, put some in a plastic garbage bag and hung it in that same place I described for a rock, and let it set there. Then I took off the bag, and I have a form-fitting rock that can be removed if you wish. The extra weight will keep the wheels down, and make the tiller more manageable.
Mar 07, 2010 | Troy-Bilt Pony Garden Tiller
I have sony vaio model pcb-9p3p I am looking for replacement keyboard but i dnt have part code. Pls suggest me wht to buy
Take a look at the keyboard plug and buy any keyboard that has the same plug. It will be either USB or PS/2.
Apr 29, 2009 | Computers & Internet
I have a 2000 dodge dakota and i bought a universal h20 sensor and i need to know what the wireing digram for the sensor is the colors on the truck are orange/green and yellow/white and black/blue and...
Ok, the truck - org/grn goes to one of the sensor heater wires (wht).
The truck - blk goes to the other sensor heater (wht).
The truck - blk/blu goes to the sensor ground (grey)
The truck - yllw/wht goes to the sensor signal wire (blk)
Apr 07, 2009 | 2000 Dodge Dakota Quad Cab
1991 318i bmw 4door sedan engine keeps cutting off
hello right have u had service done recently may be sh**y plugs check oil lvls and get her running with someone reving and unplug air flow meter se wht happens if theres no change in engine noise it prop tht otherwise take off air intake pipes etc check for blockages (very rare) i can also suggest common fault is pipe from air flow meter to the engine suffers dramaticly from lil cracks and alsorts check tht over completely and the hoses beneath it try all tht first if you dnt have any luck thn start thinking fuel filter alot of crappy fuel about nowadays but i rekon its your pipes either crackes of poped off let me know how ya get on
Jan 02, 2009 | 1999 BMW 318 ti
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
