Question about Panasonic RX-FS430 Cassette Boombox
Audiocasette will not eject
We played an audiocasette in our Panasonic RX-FS430 "boombox"-type AM-FM radio and tape player. The tape played fine, but when the "Eject" button was pushed, the door opened but the casette would not release. Is there a way to release the audiocasette without damaging either the casette or the tape player? If we have to sacrifice the casette, that would probably be ok, as long as we could use the player again. We are seniors and read about your website in the AARP magazine. Thanks for any help. My email address is igloogirlinator@gmail.com. Marie
SOURCE: Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Posted on Nov 23, 2006
philipp
  • 217 Answers
SOURCE: Panasonic PV-GS150 wont eject
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 18, 2007
SOURCE: I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Posted on May 06, 2008
leecom72
  • 4806 Answers
SOURCE: Panasonic Palmcorder PV-43D cannot get door open
Hi there.
Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Good luck and thanks for using FixYa!!
Posted on Apr 21, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Posted on May 21, 2009
Will it record on most cassette types
The difference between cassette types is the length of the tape and the quality of the tape. Your recorder will work on all types of cassettes.
Dec 17, 2015 | Panasonic RX-D55GC-K Boombox - High Power...
Tape deck on Panasonic RX-DT680 boombox issue
I think this should be a simple fix! The deck will have switches at the top of the cassette compartment. These detect the tape and also select it for type - metal or chrome etc. These switches have become bent or damaged or have dirt on them.
May 18, 2013 | Audio Players & Recorders
FM Band not working why is it?
If the am is working and fm is not, check to make sure antenna is extended all the way, also adding a long wire to the antenna rod will increase range, if no change! the fm section is defective and replacing the whole unit is the only option.
Mar 03, 2012 | Panasonic RX-FS430A Radio/Cassette Boombox
FM band not working
If the FM band is not working, make sure rod antenna is fully extended, wrap wire around the antenna for better gain, if still no result the FM section is defective and is not cost effective to repair.
Mar 03, 2012 | Panasonic RX-FS430 Cassette Boombox
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
Nov 13, 2009 | Emerson PD6810 CD Boombox
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Insignia NS B2110 boombox CD not playing
Try an audio CD which has been purchased. I think you have MP3's on your cd and your boombox maybe does not support MP3
Mar 07, 2008 | Insignia Sport lDM9700-2 Personal CD...
Panasonic RX-FS430 Cassette Boombox Logo
57 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
