Question about Alpine SPX-17 PRO Car Component System
I have a pair of 6.25 alpine SPX177r, and the crossover isamazing and want it hooked up rite...thank u
2 Suggested Answers
  • 47 Answers
SOURCE: tri-mode amplifier hook-up
you dont have to have a crossover to hook up ur amp 2 ur subs
Posted on Feb 28, 2010
How to hook up alpine 3653?
Instructions
    • 1 Determine the distance between the system amplifier and the 2-way crossover. Cut this with the wire cutters. Strip 1/2 inch of insulation from the amplifier end of both speaker wires. Loosen the amplifier speaker screws with the appropriate screwdriver. Insert the bare wires under the terminals strips. The speaker wire with the writing or molded ridge is usually used as the positive wire. Tighten the wires down with the screwdriver.
    • 2 Route the wires within the vehicle, avoiding potential hazards such as floors, seatbelt areas, and anywhere where small stressing or abrasion may occur. This usually means under side trim or tucked within the dash. Secure any loose speaker wire with zip ties every 4 inches.
    • 3 Remove 1/2 inch of insulation from the crossover end of the wires. Locate the section of the speaker terminals labeled "INPUT" or "AMP." Insert the wires leading from the amplifier under this strip, following the same polarity used at the amplifier. Screw these down with the appropriate screwdriver.
    • 4 Cut lengths of wire to connect from the crossover to the woofer and tweeters. Strip 1/2 inch of insulation from both ends of the wires. Crimp a 16 gauge insulated connector onto the tweeter end of the speaker wire leading from the crossover. Insert the wires under the loosened screws labeled "TW" or "TWEETER." Tighten these back down to secure.
    • 5 Strip 1/4 inch of insulation from the wire pigtail leading to the tweeter. Insert this into the other end of the insulated connector, and crimp it securely. Repeat for both tweeters.
    • 6 Crimp a 16 gauge female spade terminal on the ends of the wires leading to the individual woofers. Slide these over the appropriate terminals on the woofer, again following the same polarity observed at the amplifier. Insert the crossover end of the wires into the "WF" or "WOOFER" terminal on the 2-way crossover. Tighten them back down to secure.
Read more: http://www.ehow.com/how_7175673_hook-up-alpine-2_way-crossovers.html#ixzz32AMgzu8S
May 19, 2014 | Alpine 3653 2-channel Active Dividing...
Tri-mode amplifier hook-up
Feb 27, 2010 | Alpine MRP-F600 Car Audio Amplifier
I have a 04 silverado do i need to install my component speakers in series or can i hook up woofer to factory wing and tweeter seperate from factory
With component speakers it is imperative that both the speakers be hooked up to the supplied crossover. Wiring them in series or parallel will not yeild satisfactory results since the woofer requires lower freequency then the tweeter, which plays the high notes.
Now some cheaper speakers do not use crossovers and sound rather poor. What make and model of speaker are installing? Does you truck already have component speakers in it?
Cheers,
Jan 06, 2010 | Alpine SPS-600C Car Component System
Hooking i phone to alpine iva-d300 car cd player what's needed?
you could just go to walmart and but a ipod/iphone radio adapter. all u do is hook the iphone up to it plug it in the cig. lighter and turn it to the rite radio station. there should be a station switch on the adapter
Sep 04, 2009 | Car Audio & Video
When I hook my JL W7 sub to my alpine mrd m1005
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Jul 05, 2009 | Alpine CDA-9827 CD Player
Car audio
As long as the crossover keeps the frequency going to the tweeters within a safe range (I'd say about 500hz+, read the box or look it up by model number) they should be just fine. That is what the crossover is for.
Apr 01, 2008 | Car Audio & Video
Alpine SPX-17 PRO Car Component System Logo
249 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
