Question about Toshiba Satellite A135-S2276 Notebook
Need help with toshiba dynabook satellite 1801
I formatted the laptop but it will not start to boot.. it always say '' sorry for the inconvenience''. and if i selected start widows normally it will hang....
  • 73 Answers
In this case the hard drive is still affected. you need to format the entire drive if possible remove it and connect as slave on another machine and format before you reinstall. its hectic but please do it wit a lot if care.
Posted on Apr 14, 2009
    Scholar:
  • 44 Answers
If you formatted the laptop then you shouldn't even get a screen asking to start up windows normally. Do you still have the recovery partition? You can test by shutting off the laptop, press and hold the '0' key, turn on the laptop, one you see the startup screen release the key. You should then get a white bar load across the screen with the words "Loading Windows Files" above it. That will start the re-installation of windows to factory defaults.
If you don't have a recovery partition, or it was formatted then hopefully you have the set of recovery discs that the computer would have asked you to create. With those you can boot from the discs and re-install windows from there. (I can't remember which key starts the boot manager for toshiba, I think it was 'Esc')
Hope that helps :)
  • 326 Answers
Sounds like you may need to re/install or update some drivers.
Attempt to boot the machine into Safe-Mode.
Continuously hitting F8 while booting will get you to the Boot Option Menu.
If you can successfully boot into Safe mode, this may be enough to put things back together.
Attempt Safe-Mode and if successful try a normal boot.
Start from there and let us know the results.
Toshiba bios password removal process is meant for use on Toshiba laptops that you own or have had permission from the rightful owner to remove the password. If any of these processes are done incorrectly it may result in complete system failure or permanent system damage (you've been warned!).
Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk. Format the disk using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you'll be asked for a password, just press Enter. Then when you're asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Aside from the KeyDisk, you can build a parallel Loopback plug, this is a simple device that plugs into the parallel port of the machine and removes the password when you boot it up.
To make it you will need a 25 pin DB25 plug, take the plug apart and join these pins using some old cable;
Pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, and 18-25
Plug it into your parallel port and boot up your machine, the password should be removed as soon as it boots.
Note: This will work on majority of older Toshiba's (1995 – 2002) and obviously only ones that have a parallel port.
Apr 28, 2010 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba. system will not booth
Assuming you are using XP.
In Control Panel in Power Option
In Advanced tab set your options for when you press the power button and the other events (lid close .....)
Jan 06, 2009 | Computers & Internet
Toshiba Dynabook satellite T11 130C/5
I can assure you that that part number is out of synch with Toshiba's sequences. Close, but no cigar. Did you buy that from Toshiba direct, or somewhere else. I have a toshiba tecra myself, so I go to their support center when I need help.
Feb 17, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
213 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
