Question about Ericsson Cell Phones
My daughter dropped her phone in the salt water pool
It still goes but the reception is terrible , its a buzzing sound , can it be fixed ?
2 clean d virus
Posted on Apr 14, 2009
How can you decrease copper levels?
copper levels have to be lowered by delution (adding more water)
your daughters hair rinse with lrmon juice the reason this probably happened your PH and alkalinity are both probably low PH should be between 7.2 and 7.6 alkalinity shouls be between 80 and 120 if un aware of pool chemistry take water to a professional
Jul 14, 2014 | Intex Automatic Salt Water System for ...
High copper, High alkalinity, No chlorine & salty water
call in a pool expert to help you set up the system properly and to check the chlorinator
from your statement you are making things worse by not fixing the problem
Mar 18, 2017 | Intex Automatic Salt Water System for ...
I have had my intex saltwater system since June. It has done wonderful up till now. I keep getting a high salt error. I haven't added any salt. what could be wrong?
Have you had a lot of water evaporate from your pool from the heat. As the water evaporates the salt content in the pool goes up. If so then drain a fair amount of the water out of the pool and add fresh water to fill it up again. Also unscrew the connector on the right side of the electrolytic cell and make sure the plates are clean. If that doesnt fix the problem than you may have to replace the cell.
Sep 05, 2010 | Intex Automatic Salt Water System for ...
In three days my electode is clogged up my salt build up.so I get a low salt alarm
ok, it is time to stop guessing on how much salt to add or take out.
You need to be as close to 3000ppm as you can
anything under 2700 and you will not generate enough chlorine. any thing above 3500 and you can go cloudy, have build up, or just plain taste terrible.
you need a test kit for salt that reads in #'s not color
the color salt kits have too much varience
If you are over, drain 20% of the pool and ad fresh water keep doing this till you get close to 3000ppm
If you are under then ad the amount of salt stated in the test directions.
Once at 3000 clean your cell again.
you should be good to go
Dont forget that once at 3000 you must keep an eye on the level because of rain and adding water for splash out
Aug 29, 2010 | Intex Automatic Salt Water System for ...
My high salt light keeps coming on and no salt has been added
The only fix for this is to remove some salt. You do this by removing some of the water. Without the benefit of a proper test kit, it is difficult to tell you how much water to remove ... I would suggest you drop the level 8 to 12 inches, add fresh water and see what happens. If the salt is still too high, wait a day and remove another 8 to 12 inches.
Thanks for your interest in FixYa.com.
Aug 20, 2010 | Intex Automatic Salt Water System for ...
The filter wasn't changed for a couple of weeks and lots of leaves fell in our pool, I changed the filter put more salt but the pool water is getting greener and greener every day, what can I do? Intex...
Shock your pool ... take it to about 20 ppm and run the filter 24 hours a day. Brush the sides. When the pressure goes up 10 lbs over fresh start pressure, backwash or clean your cart as appropriate. Is your salt cell calling for more salt? Salt is persistent in the water (like CAL, salt doesn't just go away. The only way you loose either is by splash out and/or backwash.) If you dont know the level and your cell will not tell you, get tghe level checked at your pool place. You should have around 3200 ppm salt. Dont expect your salt system to keep up with the green stuff when the green stuff is established. You MUST use dry or liquid CL to overcome. You MUST brush the pool sides and bottom. You must run the filter 24 hours.
Between the green stuff and the sun, the CL your cell is making is consumed almost as fast as you make it.
Get your Cyanuric acid level to 80 ppm.
I hope this helps you ... Thanks for your interest in FixYa.com
Jul 31, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Need code info
code 91 is low salt
do not just guess at it! even the recommended amount in the manual is just that, a starting point
It is up to you to fine tune it
Get a salt test kit that reads in #'s not color
Now get your pool to as close to 3000ppm as possible
under 2700 will cause the system to not produce enough chlorine
any higher than 3500ppm and you can go cloudy, trigger high salt alarm, and even taste terrible
Here is a link to manuals so you can see all other codes
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Jul 28, 2010 | Intex Automatic Salt Water System for ...
My SGH E250V used to take photos upside down but now it takes mirror image, also the reception is terrible really echos or keeps breakimg up, I have been told it is a soft wear problem.
yeah it sounds like. any water damage? maybe you dropped it? you cant really fix those types of problems but maybe you could get a replacement for free
Jun 27, 2009 | O2 Samsung SGH-E250 Cellular Phone
I have a saltwater pool system that was recently set up and the water seems to have a slight green tint to it and the walls and floors are slimy. Can you ''shock it'' with salt in the water?
yes but yu need more than just salt take a sample of water to pool shop you have way to much phosphurus in the pool you will need a shock tratment that has to be poured through skimmer box that goes through filter and increases pressure mommenterally salt alone will not fix. alkalinity is buggered as well you will need a buffer powder as well to get on top of it get water tested so you dont just waste your time
Jun 06, 2009 | Intex Automatic Salt Water System for ...
My phone got wet help
I took the phone apart and used an electrical contact cleaner on the phone and sprayed the hell out of it minus the battery which you will have to buy a new one. The put a fan on it for a day then let it sit on the dashboard of my car for a day. Put it all back together and it works Mine was dropped in 18 feet of salt water
Oct 30, 2008 | LG VX-8700 Cellular Phone
Cell Phones Logo
49 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
