Question about Datalogic QS6500BT Barcode Scanner - Barcode Scanner
Barcode Scanner not working
The charger base is flashing orange light on switching on the charger. On pressing the scan button, orange light glows on the scanner also. Charging Light on the base is green. I tried resetting the scanner by pressing the reset button on the base but it is not helping. Please suggest
5 Suggested Answers
  • 279 Answers
SOURCE: Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
Posted on Aug 28, 2007
  • 58 Answers
SOURCE: Datalogic QS6500BT barcode scanner and 2D codes
Usually some symbologies are disabled at default.
i think you need the manual and scan the barcode to enable it for scanning.
the links is:
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=R44-2816A
it's chapter 6-191 or page 279 in pdf.
you have to begin with scanning "Start" en end with scanning "END"
becarefull with printing this page and not the whole manual. there are 336 pages.
good luck
Posted on Jan 16, 2009
SOURCE: The scanner is scanning but no data is transmitted to the PC
I also purchased a Symbol LS4071 and when I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector - the connector is split like a "Y") I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
SOURCE: i scan barcode into notepad ....computer goes haywire
heare are the manual but i search a manual whear i can enable the code 93, has any a idea?http://www.barcodemuseum.com/Datalogic/Manuals/dlc6000_820000512.pdf
Posted on Jan 21, 2011
I changed the battery in my ms9535 & now it doesnt scan
First ,make sure to let it charge over night. Second, you may need to scan the bluetooth barcode located on the top of the charging cradle. This will tell the scanner which base to communicate with. If the charging cradle has a solid blue light, then the bluetooth connection is good.
Aug 07, 2014 | Metrologic Instruments MS9535 VoyagerBT...
Honeywell 2020-5 suddenly stopped scanning. The lights are on the charger base, but the scanner seems dead.
I guess there is a problem with the base station. Let me tell my story:
I got a 4820 scanner with 2020 base. All worked fine till I experimented with scanning images. After a few images (which I cannot retrieve/receive properly due to lack of software) the scanner seems dead. From time to time a short buzz sounds when triggered, but no light or else.
So I bought another 4820, a slightly different model. Seems to work fine but has to be paired with the base to get the data. Now after pairing this scanner shows the same issues as my first and refuses to scan.
I installed QiuckView and HSM-USB-Serial-Driver on a virtual machine at my MAC to flash firmware to base and scanners. But the base device does not show up in the program (althought it is shown in the USB device table). Maybe I can try on a native WindowsPC ...
Oct 21, 2013 | Honeywell 2020-5B Cordless Bar Code...
Canon mx320 printer error has occurred 5200
You need to reset the printer. Try the steps:
• Plug in the power cord of printer.
Press Resume button 2 seconds
then press the power button until the green light on (when pressing the power button,Resume button)
• Then release the resume button, but do not release the power button.
• While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
• Release both buttons simultaneously.
• Led will blink briefly and then will glow green.
• And the computer will detect new hardware, just ignore ...
• Press the power button again then the printer will flash and. Printer is ready for use.
Feb 06, 2013 | Canon PIXMA Office Equipment & Supplies
Handset green light is flashing on and off and there is no red light. When I try to scan a bar code with the handset it does not scan. How do I replace the battery in the handset?
Hi, there are detailed instructions for replacing the battery in the LS4278 Product Reference Guide on page 27 of 414.
Use a philips screwdriver and turn the screw in the base of the scanner counter clockwise to remove the latch at the bottom of the scanner.
Turn the scanner upright to slide the battery out.
Disconnect the battery clip.
Reattach the battery clip.
Make sure the new battery is securely in well of scanner.
Attach and close latch.
Use philips screwdriver to press down gently and turn screw clockwise to lock latch in place.
Feb 08, 2011 | Symbol LS 4278 Barcode Scanner
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Scanner won't read the barcode
you read the code base?
Try another computer, if it is the same, council liaison without base.Direct bluetooth.
Dec 17, 2008 | PSC Quickscan 6500 Handheld
My scan doesn't work
If the power led not glows then check the power line and adapter.
If glows, open the scanner lid, press the scan button see the scan light (the lengthy tube) is on and the scanning part is moving.
The high resolution selection may some time hang the system.
Look in the task manager whether the scanner is working.
Reinstall the scanner.
Apr 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Nov 04, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Datalogic QS6500BT Barcode Scanner - Barcode Scanner Logo
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
David Payne
David Payne
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
