Question about Apex Digital GT1417DV 14 in. TV/DVD Combo
Can't play DVDs
The TV works perfectly. The DVD player can load a DVD and play all the previews until it gets to the main menu and then it will not actually play the DVD. When I press the play button on the TV or the remote, a little white hand pops up on the upper left hand corner. What does that mean and what can I do to fix it?
    Genius:
  • 1,003 Answers
TRY PUSHING the ENTER BUTTON on remote TO START MOVIES THAT DONT ALLOW MOVIe to start when play button is pressed.
Posted on Jan 16, 2008
SOURCE:
My DVD and VCR in one has always played DVDs, and now when I tried to play a DVD, it says playback feature may not be available on this disc. I've played the same DVD on the same tv perfectly before!!
sometimes the discs get scratched enough that the player has difficulty reading them, using some car wax on the disc to clean it may help
Mar 09, 2013 | Televison & Video
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
My sister and I just purchased Beauty and the Beast Diamond Edition that includes the dvd and blu ray disc. When we put on the blu ray disc it played the previews in the beginning and then went to the main...
If you hit "Disc Menu" on the remote just as the fireworks start, you won't have to go through the entire Previews section, and then the disc seems to work fine...
Oct 11, 2010 | Samsung BD-P1500 Blu-Ray Player
Our sd-k741 player is playing previews but not the actual movie itself. Once the previews are finished, we get to the main menu and then we hit "play movie" and we get an circle with a slash through it and...
www.tacp.toshiba.com/tacpassets.../sd-k741/docs/sd-k741_om_e.pdf
If it does this with Any/Every movie no matter what, then your "Brain" in your unit, has gone faulty, and is freezing at the Load the Movie loading instructions, perhaps bad RAM, or a HDD problem whatever, you will have to get it serviced.
Jun 01, 2010 | Toshiba SD-K741 DVD Player
I have the Samsung BP-P1500 Blu-Ray player and on about 75% of the movies I put in will not work. It will work until I get to the main menu and when I select to play movie. It will load and send me back to...
Hey AJ,
Follow this link: http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=BD-P1500 Click on firmware under the downloads tab. Download the upgrade guide and it will instruct you on how to burn off a copy of the updated firmware for this model and load it into your player. It should take care of your issue.
Rob
Feb 21, 2010 | Samsung BD-P1500 Blu-Ray Player
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Black rectangle at bottom of screen when playing dvds on sony dvd player
Had the same problem but was able to fix it by simply doing the following:
"this is closed captions turned on your TV. get your original TV remote and look for a button that says "Captions" or "CC", and keep pressing it until the TV says "Off". if it doen't have one of those buttons, you will need to get into the menu of the TV and turn off closed captions there. It is probably set on "Text1 or Text 2" right now, and it needs to be set on "Off"
Apr 02, 2008 | Televison & Video
Apex Digital GT1417DV 14 in. TV/DVD Combo Logo
192 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
