Question about LG WM2688H Front Load Washer
1 yr old geting a error code TE when in cycle & shuting down.
  • 5 more comments
  • jlbouchie Sep 13, 2007
    where is the thermistor located and can I do this on my own.
  • Piglito Feb 17, 2008
    I have the same problem too. I would like to clean the contacts on the thermistor - where can I find them?
  • bmtasch01 Jan 10, 2009
    I have the same problem and I went as far as replacing the main control board and put 12-15 thermistors in. I would like to know why is this machine burning them out or do I have a different issue somewhere.
  • MaximumMccoy Mar 08, 2009
    2007 2 year old Steam washer, tE error after purchase, 1 year later had the main board replaced, and Thermister. 1 year later still occurs. Now its out of warranty and they want to put another Main Board in.. $$$$? Any Solution? or is this by Design?
  • Anonymous Mar 18, 2009
    I have LG wm3677hw an error code tE keeps shutting down the machine.  The repair man is at a loss.  It was not fixed with any of the parts/suggestions of LG's and now there is nothing else do be done.  I will never buy this brand again.
  • Anonymous Apr 15, 2009
    I have an Lg front load washer in blue this machine is a disaster. Continuous te codes and smelly tub no matter how many times you clean it.
  • Anonymous Mar 14, 2014
    how to fix
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Posted on Oct 29, 2007
Te means the thermistor is not in circuit,( contacts could be dirty disconnect plug and reconnect )should work on cold water or if it is washer dryer combo the thermistor on the dryer could be faulty
Posted on Sep 13, 2007
SOURCE:
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
I have a LG2487hm washing machine, the geek squad are a bunch of idiots. I have the TE code it only trips off line when the load is heavier than 3 or 4 towels. I looks like it is weight related. right...
TE is a Therrmistor error, The thermistor senses the water temp. As with any error code it could be the part, Wiring Harness or Computer which is causing the issue. If you try cold temp wash the cycles may work. Geeks should OHM out the part to see if that is at fault. LG has 2 different Thermistors. 1. Thermistor is part of the heat element.
2. Thermister is separate. LG part# 6322FR2046C.
Quick easy fix.
Hope this helps.
Mike
Oct 31, 2017 | LG WM2688H Front Load Washer
My LG washer is displaying the te error code and it keeps shutting down. What do i do?
'te' for an LG normally means 'heating error' (Temperature).
(It might be worthwhile trying this but sorry, no promises 1)
This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle or two of boiling water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 11, 2011 | LG WM2688H Front Load Washer
Hi all, I have an LG WD-1049C front loader 7.5kg machine. Its about 4 years old and I've never had a problem until now. I get a error code being "FE", which the manual says is "Water...
Are you sure it is not an "tE" error code. Sounds like a thermistor error. A $6 part. Kinda easy to replace but must turn washer on its back or side to get to. Answer back with a comment to this answer if you want more info or repair guidance.
Mar 30, 2017 | LG WM2688H Front Load Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
I have a front load LG washing machine. Its two years old and it stopped working today and it is giving a code of TE on the read out. what does this mean? Any help would be greatly appreciated!
TE is a Thermistor error.
This can be a shorted Thermistor and or a bad heater element. These items are located at the front bottom of the washer's tub.
If you have a washer with steam function. It could also be the steam generator's thermistor and or a bad heater element. The steam generator is located just behind the dispenser’s housing on the top left side.
I can get you part numbers is you need them.
Mar 14, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code tE
tE is a thermister error. (temperture sensor) Located at the water heater element.
Jul 06, 2009 | LG WM2688H Front Load Washer
LG WM2688H Front Load Washer Logo
1,665 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
