honestly matthew,if you need a manual.i would have to say,you should let someone with expertise install it because, a manual can tell you alot of things you should,nt do to prevent from frying your board on installation.you could ruin your board before you get it install. good luck think twice before you make this step
I had a failed mB as well,, was about to trash my LB, but then found these guys in Santa Clara Ca... my advice: same as above.. FORGET trying to install a new MB.. even removing the old one is tricky for experts..
Call Bruce at 408 988 6611 E-Shops laptop repair in Santa Clara.. they have fuji 3500 series MB's.. anyone there can help you... tell them Jay sent you.. they are all great helpers and know what they are doing.. and value conscious.. you will not be disappointed.. (I am using my repaired 3510 to write this from Costa RIca right now.. Jay
blank white page popping up not letting me go any further. In front of my home page or a game im...
(More)
blank white page popping up not letting me go any further. In front of my home page or a game im playing
I removed the screen and exposed the power button circuit board. I checked for voltage and only...
(More)
I removed the screen and exposed the power button circuit board. I checked for voltage and only found 19vDC on the main pin. Looks like either this pin has a bad solder connection, or a resistor (or fuse type part) is burned out. Where do I get a schematic for the power supply circuit (MX6448)
have dell 1555 with Vista Home Premium. Have MSN as homepage. Now get broken link to home page and...
(More)
have dell 1555 with Vista Home Premium. Have MSN as homepage. Now get broken link to home page and cannot get to msn.com. Gives me error related to dell v14 msn. any known problems or solutions?
LIfebook N3510 indicates lights on but nothing happens when i press the power button. I have changed...
(More)
LIfebook N3510 indicates lights on but nothing happens when i press the power button. I have changed the fan, hard drive,CMOS batt and Ram.still nothing is working.I need help on this.
