Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Constant flashing green light
Wd62525 format board. replaced the caps and still havethe dreen light flashing. What else could be wrong with it
  • blokh3d Apr 16, 2009
    I actually have worked on it and replaced numerous caps. I now have a picture but I now have flashing horizontal lines/distortion. Its not unwatchable but very annoying
I had the same problem. When I checked the lamp (that was only 6 months old) it looked good. I had a tech come out and he put in a new lamp and solved the problem.
Good Luck!
Posted on Apr 16, 2009
I have a mitsubishi 62" wd62525, I replaced all
When you unplug the set it then when powered up waits for the DM unit to boot up----the green light blinks on the front for about 70 seconds and when it goes out the set can be turned on.
If this is the case I have a suggestion, let me know if I have described the situation correctly.
SD TECH
Oct 25, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My Mitsubishi WD-52527 has a constant blinking green light. There is no video and no audio just a blinking green light when it is pluged in
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options for you.
1. Have it fixed by a professional 2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It'scalled: Fixing the Philips Turns/shuts off on its own problem. Hope this helps and Good luck.Kaufman605
Dec 11, 2010 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi tv wd62525 status light keep flashing
you have 4 bad caps. on the dm module they are i think 3300 uf at 16 volts im not real shure about the valu its been awhile but they are the only electralictic caps on that module
Feb 04, 2010 | Televison & Video
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
