Question about Toshiba Satellite 1955-S805 (PS197U-000LEV) PC Notebook
Pink screen toshiba satellite 1905-s805 after reformatting the screen goes pink in xp and flickers. i can still adjust the brightness or use an external monitor. whats the solution than me not having to buy a new motherboard?
  • 24 Answers
You have bad matrix, not motherboard. Change LCD matrix
Posted on Apr 14, 2009
Dear sir i have a toshiba satellite 1955-s805.but i have not a driver video card driver... if you know the web side to free download software... plz tell me,,,thanks
Go to this site, select Laptops, Satellite (family), and your model number. Note that you wrote S801 in the title and S805 in the body of your message so be sure you select the right model.
Dec 16, 2010 | Toshiba Satellite 1955-S801 Notebook
How to adjust screen brightness on Toshiba Satellite 1005-S157
You can adjust the the screen brightness by hold down the FN key and hitting F6 or F7. F6 will decrease the brightness and F7 will increase the brightness.
Jul 13, 2010 | Toshiba Satellite 1005-S157 Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Pink screen
Not a motherboard issue. If the screen looks pink it means the backlight tube inside the screen ain't reaching full brightness (the tube has gone bad). If it flickers? Well... remember them good old florescent tubes and what happened when they go bad? Same thing.
You have a bad tube in your screen and ... hence, a defective screen.
Apr 14, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Can't stop Win XP Toshiba Satellite laptop from going into standby.
on the desktop right-click properties and go to the tab screensaver.Then change the time before screensaver appears or click power and adjust the settings as you want.Hope this helped
Oct 30, 2008 | Computers & Internet
Toshiba Satellite 1955-S805 (PS197U-000LEV) PC Notebook Logo
261 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
