Question about Refrigerators
Fridge/freezer trips plugs when turned on
How do i check if the defrost element has gone. my fridge/freezer trips my plugs swich when I turn it on.
  • Refrigerators Master
  • 4,655 Answers
If it trips the breaker would recommend checking the compressor for burn out unless you know for sure the elements have direct short causing this to happen. I think the compressor may have a short, start relay,or start capacitor is defective. Let me know what you find. Could be a bad breaker or too many things on same circuit, send model and make number so I can help you better, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 14, 2009
  • John Tripp
    John Tripp Apr 14, 2009
    Have I helped you in any way? Do you need more help resolving your diagnosing the defrost element? I offer free help, you can call me or email me . Let me know.
    seabreezehvac@yahoo.com
Fridge freezer keeps tripping the electric
This is the defrost element that is located behind the panel in the freezer afraid to say it has gone open circuit and will trip the electrics everytime....you can buy the part and it can be a little tricky to fit but not impossible if you have a litle diy/electrical knowledge. The element is fitted around the evaporator and comes on within the normal defrost cycle. The element has 2 connections which are just plug in and will require no real electrical work just push fitting.
Hope this helps
Nov 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Got a hotpoint ffa97, freezer was still cold and no alarm had gone off to say that that there had been a power cut yet the fridge temp had risen enough to curdle milk??\r\ntemp gauge was still showing...
Milk can sometimes curdle in a working fridge. But it does sound like your defrost system may be malfunctioning. Can you empty your freezer and inspect the defrost system behind the air circulator fan?
I know that defrost elements sometimes go bad and the controllers can pop too. You should check your operators manual and see how to put the fridge into manual defrost. *(it usually involves turning the fridge light on and off by hand. See if the freezer drains during manual defrost. If you have lots of food that dries out in a frost free unit the moisture contains a lot of contaminants that can plug the defrost drain. Which leads to a blocked air passage between the freezer and fridge sides.
You might want to get a small backup fridge for a while to run this down.
Or just use up the food in your fridge before running the tests.
Good luck and be careful.
Jun 28, 2010 | Hotpoint Refrigerators
It keeps tripping its a whirlpool american fridge freezer
does it trip as soon as you turn it on. If so then it is ur defrost element this is situated behind the panel in the freezer at the back.
Hope this helps
Mar 15, 2010 | Whirlpool Freezers
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Refrigerators
Fridge compartment constantly icing up in one area... suspect fan to be the problem, also when compressor starts RCD sometimes trips! can you help?
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model may also be termination switch inline with element
thumbs up
Aug 17, 2009 | Refrigerators
The freezer is freezing to the extreme fridge not cooling at all
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model also check the termination switch inline with the elements
Aug 09, 2009 | Refrigerators
When i plug in my fridge freezer it trips all the kitchen circuits
it can be the defrosting element try to disconnect the defrosting element first and if it still trips the power the motor are down to earth means it was struck by lightning
May 17, 2009 | Samsung Refrigerators
Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Jun 18, 2007 | Viking VCSB423 Side by Side Refrigerator
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
