Question about MSI 865PE Neo2-V Motherboard
THIS MOTHERBOARD NEED DRIVER FOR SATA CONTROLLER?
I HAD PROBLEM AND I TRY TO FORMAT AND I MAKE SOME CHANGES IN BIOS SET UP BUT I DONT REMEMBER WHAT I CHANGE WHAT CAN I DO?
  • 371 Answers
If you have an installation disk for the motherboard, (and if you do not have one, or one is not supplied by
the manufacturer, either obtain one or you will have this problem again) then simply reinstall and the bios
should revert to factory condition.
Posted on Apr 14, 2009
I have a gigabyte motherboard ga-z77x-ud3h, a new system install a samsung SSD with the OS loaded to it Windows 7 (64bit) ultimate and a 2TB hard drive that is not displayed in windows, however both drives...
Hello here is the homepage for the mainboard:
http://www.gigabyte.com/products/product-page.aspx?pid=4153#dl
If you choosed to install windows in ahci mode, you have to make this setting again in order to boot correctly from the drive.
Is the 2 tb hd visible in the bios ?
If so you have to format the drive in the windows system when running, in order to use the drive.
A format of a drive can also be done when installing windows.
If the hd drive is brand new its not formated.
A youtube video will show you how you do this:
http://www.youtube.com/watch?v=wzXoqZTxl_Q
Remember also to use the ahci setting first for this drive
in the bios ( if available )
Remember also to format the drive in NTFS file system.
Also remember a format will erase ALL files on the hd drive.
Good luck
Sep 15, 2013 | Gigabyte Computers & Internet
Need manual for C51GU01
In the bios there's an option to configure SATA as "IDE", "AHCI", or "RAID".
If you don't have data to loose, try this. Install the drive, set the BIOS option to "IDE", boot to windows, install manufacturer's IDE/SATA controller drivers, restart, set the BIOS option to "AHCI".
AHCI stands for Advanced Host Controller Interface. There are rumors that setting AHCI without manufacturer's drivers will give you a BSOD. I'm not sure if you can recover it by switching back to "IDE", but it should be worth a shot.
Best of luck
Aug 13, 2012 | Intel Motherboard
I can't install windows xp on a sata disk
Some of the motherboards treat SATA as a seperate controller, hence you need to change the BIOS settings to emulate IDE settings or while installation you can press F6 while the installation starts and give the driver disk (XP accepts only Floppy disk with the driver files copied in the required format).
Please revert with the make and model number of the computer or motherboard for further clarification.
Jan 04, 2011 | Computers & Internet
HDD problemon asus motherboard p5rd1-vm
You need to install the SATA drivers that belog to your specific motherboard.
When you are installing Windows thru your Windows CD, there is a moment at teh beginning of the process that you will be asked to press F6 if you want to install 3rd party drivers.
That is your call.
Once the SATA drivers are installed, you will be able to continue with your Windows installation.
Don't forget to rate this answer if it helps.
Dec 11, 2009 | ASUS P5RD1-VM Motherboard
Sata isnot reconized in bios nor will it install xp on a sata drive it starts to load all files then when to enter to set up xp home sp-3 the board is new been shelved then it gives windows cannot be...
Look up the specs. on the mb and find out if it supports sata1 or sata2 drives.
Your motherboard should have four sata ports and you may want to change to another port.
Also, you may need to format this sata drive, booting from the ide drive. Windows takes a long time to format but may be the only answer.
Last, make sure your bios settings are sata as raid.
Hope this works for you, its a pain.
Nov 19, 2009 | PC Chips MB PCCHIPS K8T800 M860 V1.0...
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
"my windows cannot detect the harddrive of my computer"
Step1:Select first boot dives is HDD in bios
Step2:Select second boot device CD-Rom in bios only
Step 3:After that insert the o.s cd in your cd rom
Step 4:Restart your computer and go to setup menu by pressing the right key on your keybaord (Ex:Del key,F2 key...)
continue this prosses you will get sucess.
Sep 14, 2009 | EliteGroup ECS PT880Pro-A (1.0A) Via...
MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
Mar 12, 2009 | Intel Motherboard
Installing windows on SATA HDD
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Sep 08, 2008 | Soltek SL-75FRN2-RL Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
MSI 865PE Neo2-V Motherboard Logo
221 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
