Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
My hp 1502 has a problem.screen is white,but LED not lighted.
The moment the monitor is connected to power source,screen is ON with white screen.the on/off switch does not function
  • 105 Answers
You need to replace the bad electrolytic capacitors inside.
Monitor Mike
Posted on Apr 14, 2009
My hp 1502 lcd monitor only shows a white screen
If you don't use an identical monitors, then they may not work if your video card can not handle them. The "check video cable" it means the monitor does not get a signal, and it does not mean that the monitor is a problematic monitor. You can test this monitor as a single monitor (and try to connect it using first video port, and then move it to the second video port).
Mar 05, 2014 | HP 1502 LCD Monitor
My screen wont display
If you disconnect all the cables except the power cable, is the screen still white? White is unusual as it is the presence of all colors. Thus the white is probably coming from the video source.
If possible connect to a different video source.
Dec 09, 2013 | Samsung S22C150N 21.5" LED Monitor
Monitor flashes, turns off
Try to check both ends of the video cable if it's properly connected. Also, check the power cable connections. I'm quite sure this is not an issue of a video card.
Jun 04, 2013 | Computers & Internet
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Apr 17, 2013 | HP 1502 LCD Monitor
Can't turn off
check on/off switch.
May 30, 2012 | HP 1502 LCD Monitor
Hp1502 stays black
If you see that the monitor is on by a power on light Then the graphic card could be bad or most likely the monitor is gone to haven. Borrow a friend monitor and attach it to your computer and see the result. also check your connections monitor to computer.
Mar 24, 2012 | HP 1502 LCD Monitor
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
I'm trying to connect a Bose 802-E active equalizer (and 802 speakers) to my Denon AVR-1404 hoe theater receiver. I have it connected via analogue RCA cables to the CDR/TAPE inputs and outputs. My problem...
I'm not totally sure this will work but give it a shot.
Your remote has two slider switches on it and a "source" button. I would slide the Audio/Video Switch to Audio. And I would Slide the other switch to the "tape" positions. Then I would push the "Source" button. That may activate the traditional "tape monitor" switch functions used in traditional preamp designs. Give it a try.
If there is a jumper going from the pre-amp sections to the power amp sections, you could put the 802's EQ in that loop. I have the feeling that this feature is not part of Denon's designs.
I hope this helps,
Best Regards,
Mark
Jan 15, 2011 | Audio Players & Recorders
Screen just went black, power light on; is there any easy fix or should I trash monitor?
Try disconnecting the video source; most monitors will inform you of the missing signal by putting a warning box on the screen if they are functional. Before ditching it, I would try connecting the monitor to another computer or borrowing a monitor to make sure your internal video source is working.
Dec 28, 2010 | HP L1955 19" LCD Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
601 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
