Question about Dell E173FP 17" LCD Monitor
Dell 17' Flat screen
OK Maybe I should have asked "How do I remove the cover?"
  • 1 more comment
  • watmewory Sep 14, 2007
    Well I got a b oard through ebay that I thought would solve the problem. However, after prying open the case (this morning) and getting the other board out, I found that the replacement board had different connector sizes on it and I couldn't use it anyway. So the project is trashed and I will buy a new monitor. My setup was a dual monitor system and currently I am limping along with one monitor.
    Watmewory
    coming on faintly and then flicking off. Seems like a common problem with those monitorws. Someone said they are "throwaway" anyway.
    B
  • watmewory Sep 15, 2007
    Right now I'm thinkin' that I will just wait and buy one off ebay. I have had all the hassel with this one I can stand! Besides, I have it in about a thousand pieces, not smashed or anything, but all apart. thanks for your suggestions.
    B
    President:
  • 3,130 Answers
What is it your looking to do with this monitor?
Posted on Sep 14, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Sep 14, 2007
    Oh Ok sorry we could not help you, but what was the problem with the bad monitor?
  • Larry  Dillon
    Larry Dillon Sep 15, 2007
    Yea they are, you need a ballast circuit, very very common for these units and Dell knows it. Have you tried to call them and see what their flat rate is to repair these monitors?
  • Larry  Dillon
    LOL I do truly know how you feel my friend.
How to open the flat screen
Francois, If you really want to remove the pedestal and then rear plastic cover from the front BEZEL, then why don't you visit YOUTUBE and view some video clips of "LCD monitor disassembly" and "LCD monitor repair" to see how to "PART" the cover from the bezel!!! There sure is a lot of stuff to see on YOUTUBE. HINT!!! YOU must protect the LCD PANEL at all times!!! GOOD LUCK, 12fixlouie
Dec 11, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
How do I remove the base stand fro my Neovo F-17,
You need to remove the two plastic covers the cover up the hinges mounting screws, which are attached to the back of the monitor.
Oct 26, 2009 | Neovo F-17 W (White) 17 in. Flat Panel LCD...
Dell Flat Screen goes from good to bad
Check that the connection from monitor to computer are tight. Maybe disconnect and then reconnect tightly. The most likely problem if the connection if good is your graphics card. Most of the time these are embedded on your motherboard meaning the entire board would need replacing, some graphic cards are external cards that are easier to troubleshoot and replace. Try the connections and let me know. Is the computer older than the monitor, or were they purchased together? What is the warranty status?
Mar 26, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Screen blackout
I had the same problem and fixed it with a new backlight inverter board. It was a pretty easy install. The part is available on eBay. http://cgi.ebay.com/New-Inverter-for-Dell-W1700-17-inch-LCD-TV_W0QQitemZ400017456720QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Nov 07, 2008 | Dell W1700 17 in. HD-Ready LCD Television
No picture....just blank screen.
hi can u hear sound, if yes ,copy ur lcd name& model no &order for the inverter . then when u see that u will be able to change it .
Oct 19, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Dell 1703 FPi 17" TFT LCD Flat Panel
First there is a seprate snap frame around screen itself, there about four location on snap frame , 2 on each side ,use flat screw driver to seperate frame, there in slots like,there might be 2 on the top also,then go for screws in back, remove button panel from front side and remove flat wire connections to the board ,they pull out of slot on board , be careful putting them back in ,take your time they will go back in by pushing on the stiff part,about a 1/8 or so from the end to go in. of the connection,go for the VGA connection ,you will remve screws to seperate screen it self to get to the connection, it just pulls out of the socket on the board,hope this helps
Sep 08, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
24 people viewed this question
Clive
Clive
Alun Cox
