Question about Compaq QVision 171FS (White) 17 in.CRT Conventional Monitor
My screen doesent fit and it is hourglass shaped it is driving me nuts
My screen appears hour glass shaped and not all the way full. the control buttons on the front are not doing anything I wonder if it it broken or am i an idiot.
  • Anonymous Apr 16, 2009
    My picture is bowed in on the sides (hourglass shape). I took the back off the tv and noticed some broken pieces of plastic. After searching I found that they went to the back of the tube and they held the "color alignment rings?" in place. since the tabs were broken the rings or dials moved. I noticed that they were marked with a marker or some type of ink and realigned the rings to the marks and it realigned the color on the screen for the most part. However where the screen is streched at the corneres, the color is still not aligned.
    President:
  • 2,992 Answers
The problem is called "pincushion distortion" and happens because of the way CRT monitors work. There is circuitry in the monitor to correct the display, but it's not working in your monitor. Often this is because of bad solder connections to transistors in the circuit (they get pretty hot sometimes and can cause the connections to degrade). It can also be due to failure of those parts.
If you are comfortable working with electronic soldering and want to try your own repair, open the monitor and examine the board for bad connections. Repair any that are grainy or obviously cracked. Typically the parts that need resoldering are mounted on metal heatsinks so you have a place to start looking.
I don't recommend paying a shop to repair this. New 17-inch LCD monitors are so inexpensive today that it's better just to replace the CRT one.
Posted on Apr 17, 2009
It displays an hourglass with a black screen when you turn it on
  • turn off remove and re insert the batteries first
  • remove the memory card
  • turn on the unit . if the hour glass does not appear try inserting a different memory card .
  • if this works your camera may have trouble reading the old card
Aug 23, 2014 | Nikon D5100 Digital Camera with 1855mm...
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Power Up Hour Glass appears an stays on for 3 hours
This should help. When the hourglass symbol stays on, press and hold down the start button for at least 15 seconds. The screen should clear and then you can navigate back to the correct opening screen and select music, videos, photos etc. as you require.
Nov 26, 2008 | Archos 405 Digital Media Player
T7100
same thing to me but not off ebay when i first bought my 7100t all it would do was show an hourglass but i never used it for a month then i charged it then it worked fine
Jul 22, 2008 | RIM BlackBerry 7100t
Philips 25PT2252
Vertical hold will adjust the frequency (refresh) which would remedy it if the picture was rolling. I had to open up my TV (not recommended unless you know what you're doing) and adjust a "pot" which will adjust your screen's hourglass problem. I hope this helps.
Jun 28, 2008 | Televison & Video
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Hourglass frozen on screen!!
Try and plug it in your computer once again and see if the hour glass budges. Then safely remove it by clicking the "Safely Remove Device" Icon on your PC tray (where the clock is on a PC)...
If not, theres probably a software reset hole at the back or sides of your mp4 player, try pushing it with a toothpick or similar pointed thing.
If all else fails, have it replaced...
Dec 09, 2007 | Audio Players & Recorders
Tv screen has slight hourglass shape
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Nov 06, 2007 | Sony KV-32S26 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Compaq QVision 171FS (White) 17 in.CRT Conventional Monitor Logo
582 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
