Question about Gateway Computers & Internet
My laptop has wireless but I am having trouble getting online
I have to connect the phone line to the modem is something wrong with my gateway laptop
  • 1 more comment
  • randy_irene Apr 14, 2009
    yes I have a router but my laptop has its own internal wireless and I did the installation and I have tried everything to get on line but the only way I can if I use the Ethernet cable and I have used my laptop before and was able to get on line without using the cable so I do not know what I am doing wrong. Thank you for your help
  • ERIC BAKER May 11, 2010
    Have you gone to your wireless setting's to see if they need to be adjusted?
    Are you using a router?
    Problem Solver:
  • 5 Answers
Make sure your ip config is set to auto obtain for the wireless card
Posted on Apr 14, 2009
My Acer Aspire One D255-2256 netbook is having trouble connecting to the internet.
Start-Programs-Accessories-Command Prompt. Command prompt will open. Looks like a black screen. Type ipconfig then hit the enter key.
5th line down, you'll see something like this and so on.
IPv4 Address. . . . . . . . . .192.168.0.???
Subnet Mask. . . . . . . . . .255.255.255.0
Default Gateway . . . . . . . .192.168.0.1
These ip addresses may be different depending on what router or modem you're using. But if you're connected to the modem/router, you should get an ip address(IPv4 Address) and a default gateway that are the same except for the last set of numbers.See question marks above. If it's not the same then you are not connected to the router/modem. Check your wireless connection to see if it's on. Make sure you are connecting to your network. Make sure wireless signal is being transmitted from router.
See if you can hit the router if you have connectivity. Open your IE or Firefox and type only the IP address, meaning remove the http://www. Not needed. The IP address is the Default Gateway thst was listed in the Command Prompt. If you can hit the router/modem, then make sure that there is connectivity to the host. If you're DSL, you'll be using PPOE which is Username and Passwrd. Make sure you are connected by clicking connect under connection summary. If cable modem, make sure that the lights are on showing connectivity. Here's a starting point. I now need more info. If this doesn't help, tell me what you did find out and we'll go from there.
Jan 10, 2011 | Computers & Internet
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Wireless sgnal working but auable to connect to go online
You need to give the password of your modem in netgear settings .
Nov 25, 2008 | NetGear WGR614 Wireless Router
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
