Question about RSQ E500 DVD Player
It dont play & the cd is stuck in the player
It keeps on loading & then it will say no disc & my cd were stuck inside it dont open & close
  • joshlyn Apr 14, 2009
    its not a computer its a dvd karaoke player so theres no start & control panel with it
  • 28 Answers
Go to Start, control panel, system, device manager, find the device and uninstall it. then reboot, see if that helps
Posted on Apr 14, 2009
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
Cd recorder
follow this test and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 09, 2013 | Crosley Autorama Turntable
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
Open, closes and rotates the cd compartment, endless...
If there's a disk left over inside, It's stuck in the drive hanger, and should be removed else the changer can't put it back in it's right slot. Open the machine and check for any CD's still inside.
If not, could be that the small sensore (to the left of the head assembly (just before the drve (upside down)) is dirty or messed up.
Try cleaning if.
Jan 17, 2009 | Technics SL-PD687 5-Disc CD Changer
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Disc tray does not come out
as techman said "the old" carry with cds inside problem" yes you most have one cd inside thats the problem but letme tell you something is a problem for a cualify tech becouse to remove that cd you have to brake apart the hold cds carrier...good luck
Aug 02, 2006 | Onkyo DR-C500 Multi-disc DVD Player
RSQ E500 DVD Player Logo
172 people viewed this question
Top RSQ Televison & Video Experts
JonSnell Electronic
JonSnell Electronic
ELECTREPAIR USA
ELECTREPAIR USA
Are you a RSQ Televison and Video Expert? Answer questions, earn points and help others
