Question about Plumbing
I need help on which wires connect to which wires on my sewage pump in order to get power to it? hydromatic sewage pump sp50 I have three wire coming off my hydromatic sewage pump two black and one green. And then I have the plug coming off the power supply. I unplugged the three wires from the plug and now I dont know in which order they get plugged back onto the plug. the plug has three prongs one for each of the wires coming off the sewage pump to be plugged into. Also you cant see the colors of the wires that are on the plug.
  • 116 Answers
Its 110 v the two blacks are power and green is ground. the two blacks are reversible doesnt matter one goes to white nuetral and other to black hot. ground is ground to metal.
Posted on Apr 16, 2009
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    I have a non auto pump and want to use it with a float and also wire it so that the float can be bypassed by push button controller, hence manual operation any help please
    You install two wires at the two terminals on the float switch to a switch so that when the switch is toggled the wires will act like the float switch has closed and make the pump operate.
    Jan 21, 2015 | Zoeller 912-0073 Job Ready Simplex Sewage...
    Adjusting my Pentax hydromatic H1 water pump
    we need wiring diagram for achromatic 1. the power supply is 240 v 50 hz
    Nov 26, 2012 | Cars & Trucks
    No power to fuel pump
    First step, a simple step, check the fuse for the fuel pump and replace if needed. Step two, disconnect pigtail from fuel pump, turn ignition on to the pre-start position so that the instrument cluster is illuminated. Step three, determine with a volt meter if sufficient voltage is coming from the wires by connecting negative and positive to their respective polarities on the pigtail connector. If voltage is sufficient, then replace the fuel pump. If no voltage is present, trace the electrical line to its power source to make sure the wires are not cut or missing insulation. Repair as needed. If this does not help, take to your mechanic. Hopefully, this will FixYa problem!
    Oct 11, 2010 | 1991 Ford F150
    How to connect the 3 phase power supply to a 3 phase synchronous motor with control panel
    I assume you have 3 phase power where this is going? The panel has 3 legs, 2 are 110 volt and one is 208 volt, you will need a tester to find out which is which if it is not marked, the motor should have a map on it for the wires to attach to, they go the same way, two, 110 and one, 208, I hope this helps, There will be one wire for a ground or a solid wire separate from the unit.
    Feb 13, 2010 | AO Smith Three Phase Swimming Pool Pump...
    Some submersible pumps have a gray motor box to start the pump & some submersible pumps have the new style motor box built in and is not lighting proof. some 240vac are two wire and three! I would like...
    The difference in the two pumps is that with a three wire pump the start and run capacitors are in the gray box. With a two wire pump the caps. are built into the motor. Because of this with a two wire pump you only need to run the 240v down the well to the pump. The yellow wire on the three wire pumps is the igh voltage wire that come from the start cap. I have used both pums but usually use the two wire because they are easier to hookup and the wire is cheaper because you only need to run three wires. (2 hots and ground) On large HP pumps you will always have three wire motors because the caps. get too big to get them in the motor. It is best to go three phase with big pump if you can.
    Nov 14, 2009 | Plumbing
    Wiring a 230V 3 phase heat pump
    yes, this is quite important when it comes time to turn the motor. in 3 phase, motor rotation direction is critical importance. however, it is a simple matter of trial and error if only a fan is involved...not sure of consequences if freon pump is turned backwards...may want to remove pump wiring temporarily...so try "bumping" the fan only...your method for this "fan only" is yours to figure out. try to set to "fan only" somehow then apply power. if fan turns backwards, the take any 2 black wires and reverse connections. fan should now turn in proper direction.
    Nov 11, 2007 | Heating & Cooling
    Plumbing Logo
    297 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
