Question about Dryers
No heat on gas dryer maytag dg512 series 07
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    Joseph,
    I'm not dissin' Sea Breeze, but giving the age of this dryer I'd lean toward the igniter. If it's not the igniter (you can see it glow if it's good) it could also be the flame sensor...
    You'll need to perform a few tests to determine the culprit. Do you have a multimeter?
    SG
  • 4,654 Answers
If you could look through door panel on back of dryer while its trying to ignite you should see a glowing igniter to ignite gas. If you see the glow then I believe your gas solenoids are bad, The part number for one is 305604
Go to my web page and enter part and model numbers in the search features. I will help you find the problem, Thanks Sea Breeze
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 14, 2009
I have a maytag quiet series 200 gas dryer that will not stay heated
replace the gas valve coils on the top of the gas valve they get weak from the heat of the dryer and can't keep the valve open
Jan 11, 2013 | Dryers
Maytag dryer legency series is not drying, no heat comes out.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 16, 2011 | Dryers
Brand new dryer won't heat. Tumbles fine - but no heat. Maytag 2000 series. I already checked the breaker - no problem
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 27, 2011 | Dryers
Maytag dryer model number DE312 series 2 will not heat would love to fix it myself
heatman101
Jan 13, 2011 | Dryers
Maytag SE1000 Series 07 dryer wont heat
You need to have 220-240 or so volta ACROSS the two terminals on the element...the 125 can feed across and can be the same leg on both sides...
Check out this tip also..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 22, 2010 | Dryers
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
I have a model DE303 series 07 maytag electric dryer and it is not heating up?i am experienced in electrical
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jul 06, 2009 | Maytag Dryers
Burner not stayinyg lit
since burner is igniting, it probably is OK. next check is limit switch. this switch shuts the gas off if it senses excessive heat (blocked vent ... usually caused by lint) limit switches themselves MAY go bad ... bu rarely PS check to make sure the vent is blowing exhaust to outside of house (i've seen birdnests in the exhaust port cause your problem)
Apr 27, 2009 | Dryers
No fire
This link --->click here<--- is the exploded view for your unit. If you look at diagram 4 (gas valve), the first guess would be a faulty igniter (diagram location 12). This is only a guess for no tests have been done to narrow down the faulty component.
If you need assistance, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 01, 2009 | Dryers
Dryers Logo
143 people viewed this question
Top Dryers Experts
