I need to detach finisher from main body and then reattach once I have moved it to the next room.
How so I unhook finisher from main body of kyocera mita KM-5530
  • 43 Answers
Turn off main switch. Unplug power cord. Remove two screws where the extendable frame of the finisher connects to the copier. Unplug the connector cord from the back of the copier by pushing release button on the connector.. Done.
Posted on Apr 20, 2009
KM-5050 Finisher not attaching, Why?
Make sure the connector cable from the finisher is plugged into the copier. Unplug the copier power cord first if you have to reconnect it.
Jul 13, 2014 | Kyocera Mita KM-3035 All-In-One Laser...
Reattach backing for side view mirror
Go to your auto part store or body shop and ask for 3M mirror adhesive.
Jan 18, 2014 | 2008 Chevrolet Avalanche LTZ
Machine squeaks
see the next steps and fix it. God bless you
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 19, 2012 | Schwinn 420 Elliptical Trainer
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
I have a 2004 chevy trailblazer and whenever i turn on my a/c or heater it seems my engine losses power and wants to die.
I'm taking a wild guess that you recently unhooked or replaced your battery?
Your problem is a dirty throttle body, and if you do it yourself, can cost you about $5 for the can of throttle body cleaner. Unhook your battery again, and clean the throttle body and butterfly very well, must be shiny. Careful as the butterfly is very sharp. While removing the entire throttle body and cleaning it is best, leaving it bolted on will solve your problem too. When finished, hook your battery back up and drive around for 20 minutes or so with all accessories OFF. During this period, your computer will relearn a properly functioning throttle body.
Your computer learned some bad habits before the battery was unhooked the first time. When it was hooked back up, it thought the throttle body was clean and functioning properly. Cleaning it takes care of this problem. I do mine about once a year.
Mar 21, 2011 | 2004 Chevrolet TrailBlazer
Detach RICOH SR790 Finisher
Hello sir; Open the finisher door on the mid of right hand side ther have a cross bar fasten by one screw, loose the screw pull out the cross bar, it will detach from the machine.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
How do i open the unit up to change the battery?
A small #6 torx screw driver is needed. The GPS flap on the back has to be opened. The antenna board has to be disconnected where the ribbon wire, covered with black tape, snaps onto the board. A small blade can flip the cable lock up and the ribbon wire will easily detach. Now you can remove the plastic flap, by pulling back the spring loaded hinge. Be careful not to let the spring fly out! Once the flap is removed, two screws are exposed on the top of the main body, same #6 torx. Once removed, use a plastic pry tool to slowly move along the circumference of the body. Once all the plastic snaps are un-snapped, be very careful when opening the **** shell you've created. You should now see everything you want to mess with.
Aug 12, 2009 | Garmin nuvi 670 GPS Receiver
I moved washer and I think the basket is unhooked
Detach and reattach the cabinet.
This video will show you how to remove and replace the cabinet.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Just skip the steps in the middle of the video.
Mar 15, 2009 | Whirlpool LSR6332K Top Load Washer
73 people viewed this question
jasbo
jasbo
