Question about Dryers
Whirlpool dryer not getting hot mod# lev5634aw0
I have a wirlpool lev5634aw0. It will not get hot. i took the back off and got the meter out. it seems to get power to everything i can see to test. i think the heater coil may be bad but im not sure. when i turned it on it did not heat up, but was getting power. so if this is the problem . how do i remove it lol. i cant figure it out.
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    S,
    You were checking power (I presume voltage), did you Ohm any components?
    SG
  • 686 Answers
REMOVE THE FILTER AND THE 2 SCREWS UNDER THE FILTER LID THEN PRY THE TOP OPENED AT THE FRONT EDGES BETWEEN THE TOP AND FRONT PANEL THEN OPEN AND LOOK AT THE TOP OF YOUR HEAT ELEMENT HOUSING REMOVE THE 5/16 HEX HEAD AND PUSH IT TOWARDS THE REAR TO DISENGAGE IT FROM THE BACK OF THE REAR BULKHEAD THEN LIFT UP AND OUT IT COMES. cHECK YOUR THERMAL FUSE FOR CONTINUITY. GO TO www.repairclinic.com SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 AND CHECK THESE PARTS AS WELL. 2986, 2821, AND 2893. THE ELEMENT IS 3367. 2986 NEEDS TO BE CHECKED FOR CONTINUITY.
Posted on Apr 14, 2009
WHY DOES MY WIRLPOOL DRYER MAKE A HUMMING SOUND WHEN TURNED ON
Sounds like there's something in the lower wheel jamming the motor . GOOD LUCK APPLIANCES R EN
May 21, 2014 | Whirlpool GEW9250 Electric Dryer
Dryer not getting hot enough to dry clothes
First check the power coming in, you need 240 volts. 120 to neutral on both sides and 240 across both. If you are not comfortable with a VOM volt ohm meter call somebody who is.
Be aware when every you remove a panel you will be exposed to sharp surfaces. Unplug first and be careful!
Whirlpool dryers have a thermal fuse inside the back of the dryer, if this is open the dryer will not heat. You will need to check this with a meter it should be closed. A quick and dirty way to check it, remove it and wire it in a circuit with like a flashlite or radio. the flashlite or radio should work, this is a dirty way to check fuses if you dont have a meter.
While you have the dryer open, vacuum it out and clean the venting.
Please repost if you have more questions
Dec 30, 2009 | Whirlpool LER5636P Electric Dryer
I have a wirlpool dryer mod#LER7620LW0 the elements heat but the motor will not turn seems to turn freely by hand is it the motor or is their a start relay somewhere
maybe a broken belt, or the motor is locked put but i recommend you looking for the belt and then turn the motor by hand.
Jun 05, 2009 | Whirlpool Dryers
I can't remove the heating element case.
HI, you need to rea=move the back panel to locate the element. It will be on the right side (looking at the back) in a housing. Check continuity on the element terminals. If it checks out ok, check all thermostats.
If I can assist you further, please let me know. I can also get you parts off my web site www.whirlpoolpartssurplus.com
Vic
May 20, 2009 | Dryers
Whirlpool mod # WGD5300SQ0 gas dryer gets hot but does not stay hot Is it a thermostat or radiant sensor or something else
by all means when dealing with natural gas consult only trained professionals....as natural gas does not have an odor..the odor that you smell is an actually additive that has been place for just this reason.
May 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer does not glow or lite up but it runs
I just diagnosed the same problem with my estate model by wirlpool. It is most likely the thermal fuse located in the back (behind the panel) It is a $12.00 part. My neighbor fixed his father's unit with same issue 2 weeks ago.
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool dryer
reinstall back.. remove 2 screws under lint screen press 2 clips on front corners with putty knife lift top remove screw on each side top inside front lift front off belt goes over drum ..double it and pass through idler support arm then onto motor pulley ..belt pack may have a diagram
Jul 31, 2008 | Whirlpool Dryers
Whirlpool gas Dryer LGR5636JQ1
theres a thermal fuse located on back panel usually white maybe 2 inches tall 1/2 wide 2 blue wires leading to it. ck for continuity, if none replace that(most common problem)... if good you can go back to the ignitor and unplug the white connector it plugs into. place your meter leads into the connector and turn on dryer, you should get 110v. if you do you have a bad ignitor, if not a thermo's gone bad (check the thermal fuse first though.
Mar 12, 2008 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer
Did you check the coils for the gas valve with a meter for ohms resistance?
Aug 09, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
294 people viewed this question
Top Dryers Experts
