Question about Nikon D80 Digital Camera with 18-135mm Lens
Getting (CHR)error message on my D80
Blinking CHR. does anyone know what's wrong?
  • 289 Answers
Your SD card may be "locked." Check the SD cards slider lock and make sure it's set to allow you to write to the card.
Posted on Apr 23, 2009
  • bacov Oct 14, 2010
    I had the same problem. I couldn't take a picture......nothing worked....just kept getting "CHR" message. Thanks to the above response, I checked the SD card and determined it wasn't in the locked position. But I then replaced the micro card (with adapter) that I was using, with a standard card and the camera worked fine. Then I checked the micro SD card that I replaced and it was apparently the cause of the problem. I simply pulled out and reinserted the micro card in the adapter, put it back in the camera, and all is good to go! A lot of mysterious stuff goes on in these cameras.......
Excel Tool VBA Password Recovery
Are you looking to unlock a protected sheet or actually recover the password? I can help you with the former.
Note this will only work to unlock a worksheet. It will not recover the VBA editor password (however this is possible by very hard to explain.)
1) Open the excel sheet you want to unlock,
2) Open VBA editor, (Alt+F11 while in excel)
3) add a module (insert > module)
4) and paste in this code into the main window (big window on the right)
Sub PasswordBreaker()
Dim i As Integer, j As Integer, k As Integer
Dim l As Integer, m As Integer, n As Integer
Dim i1 As Integer, i2 As Integer, i3 As Integer
Dim i4 As Integer, i5 As Integer, i6 As Integer
On Error Resume Next
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
ActiveSheet.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If ActiveSheet.ProtectContents = False Then
MsgBox "One usable password is " & Chr(i) & Chr(j) & _
Chr(k) & Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
ActiveWorkbook.Sheets(1).Select
Range("a1").FormulaR1C1 = Chr(i) & Chr(j) & _
Exit Sub
End If
Next: Next: Next: Next: Next: Next
End Sub
5) Then either:
5a) go back to the excel window, click Developer > Macros > select PasswordBreaker
6) Or just hit the play icon (green triangle) in the top of the VBA editor
This will unlock the sheet, and give you a password which will unlock it in the future.
Note: Due to the encryption method used in excel, there are many possible passwords which will unlock the sheet. This will give you "a" password which will work but it will not be the one that you originally set up. Both the original and this one will still work.
Jan 20, 2013 | Excel-Tool Excel Tool VBA Password...
Error message on nikon d80
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Nov 10, 2012 | Nikon D80 Digital Camera with 18-55mm Lens
How I can change fontname from epl programming language, There's a command for that, "ES", but I dont know how to use it. Can anyone give me a hand ? Thanks in advanced.
This is not the correct interpretation
To change character set for example in basic you shoud send
Print chr$(27);"A12";
with small character
Print chr$(27),"A01"
The ESC = Escape (27 decimal and 1B in hexadecimal).
Aug 02, 2011 | Zebra LP 2844 Thermal Printer
How to fix the error problem in nikon d80 camera?blinking error message at the left side on the top line on display screen,ill try all ways to fix but it dsnt work,ill open the camera and align inside the...
Hi ktithender, on the left side top of the LCD on the top of the camera is the battery display and the Auto ISO display. What is it you are seeing as an error message? Also, if you are opening, taking apart the D80 there is not much any of us can do to assist you. My suggestion is to call Nikon 800-645-6689
Aug 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error Message for D80 Camera
Please, help us help you. What is the error message? If it is FEE then set you lens to the minimum aperture such as f/22. Being as you have not provided us the error message anything else is a guess on our part.
Jul 05, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error message at display screen
Set both the exposure dial and the focusmode to "M" and press the shutter button. Then turn the camera off for 10 - 15 seconds. If this doesn't solve the problem, it's an electronic or mechanical error.
Jul 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 Digital Camera with 18-135mm Lens: I have a Nikon D80 with 18-135 lens. Just had err...
Having gone over a month with no response, I assume this is no longer a problem.
May 16, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error message Chr
Having received no response in over a month, I assume this is no longer a problem.
May 15, 2010 | Nikon D90 Digital Camera with 18-105mm...
My d80 keeps reading error, i have tried adjusting lense and changing memory cards, don't know what else to try
What is the error message? If it is ERR then ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go call Nikon digital 1-800-645-6689.
May 02, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
731 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
