Question about Ovens
Ge oven sabbath mode
I'm trying to set my oven to sabbath mode, following the manual's instructions. step #2 is to tap the clock untill SAb appears - BUT that never happens! the only options that appear are 12hr, 24hr and off. help i need this set before the jewish holiday at sundown tonight thanx
  • dot88 Sep 12, 2007
    model #JGB918SEK4SS
    i just got the answer from GE - is anyone wants to know... you are supposed to press 'delay start' not 'clock'. yeesh manuals!
SOURCE:
SOURCE: Kenmore oven clock control installation instructions
powerman's solution worked great. It took me about 10 minutes. Just needed a sheet of paper, scissors and a philips screwdriver!
Posted on Jul 06, 2008
SolutionGuy
  • 331 Answers
SOURCE: GE JGRP17 Gas Oven
Rosanne, he problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN OR TURN IT OFF AT THE BREAKER!
To replace it... Remove the racks and look up at the broiler manifold. You'll see the igniter mounted at the rear (the round thing with 2 wires going to it). You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter, tuck any loose wires as far back into the oven as possible and replace the racks.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Posted on Oct 11, 2007
SOURCE: magic chef electric oven...went to
How do I replace the oven heating element in a Magic Chef oven?
Posted on Dec 31, 2008
MNfisherman
  • 11896 Answers
SOURCE: need an instruction manual for Westinghouse
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Posted on Nov 12, 2009
SOURCE: Temperature probe icon persists on the display and
If the probe is not connected, then the actual connector in the oven is faulty. If you don't use the temperature probe, you can take the front control panel off and disconnect the probe connector. I did this 8 years ago
Posted on Feb 27, 2010
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
WENT TO SET CLOCK, SOMEHOW DIS-TURBED THE CONTROL BOARD, IT IS LOCKED, READS 5A6, CAN I UNLOCK IT?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab" or "5A6.
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Mar 13, 2011 | Ovens
WHAT IS SAB
Sabbath mode. Try pressing the 'clock' pad, hold it down for five seconds and see if 'sab' blinks for a few seconds and then clears.
lp
Dec 30, 2010 | Maytag Ovens
Jenn-Air gas wall oven some how got stuck in ''Sabbath'' mode and unable to reset.
ok it happens / so to enable the Sabbath mode 1 open the door. 2 press cancel/off. 3 press the number pads 7&8 and 9 , in that order. 4 press Number pad 6 . 5 press start. "sab and on" will appear on the display ..( now to disable the sabbath mode .}. ( repeat the steps above to disable the Sabbath mode. " Sab and off" will appear on the display .. there now that wasn't too tuff was it .. mm hope this helped ..
Jul 15, 2010 | Jenn-Air Ovens
My oven will not move from SAb o 5A6 and buttons
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
Dec 12, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
747 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
