Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
I have a kenmore upright vacuum model #116.35922500. The agitator tube doesn't turn. It doesn't have a belt for the agitator. It has an overload protector. I reset it, but it keeps poping back up. Should I replace the overload protector?
    Problem Solver:
  • 4 Answers
The reset is for your safety no belt ,probly a direct drive motor issues ,maybe the brushes it is detecting a short and pops the reset.
Posted on Apr 14, 2009
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
I inherited this vacuum from my mother but I don't have the manual. I have 2 belts for it, but I don't know where they go. I can turn it on and it seems to work, but the bag doesn't fill up...
Most vacuum uses one belt at a time. The belt connects the agitator (beater bar) to the roller which is driven by the motor of the vacuum in the base of the upright vacuum.
To check if the belt is present/intact on the vacuum, look at the sides of the base for two latches. Push the latches away from each other then lift up to remove the cover so that you can check or replace the belt. To replace the belt, lift the agitator out of the base (first lift the right side). Cut off the old belt with scissors if it is still intact before pulling on the agitator. You may need to pull the bumper forward to get the beater bar out of the base. To put on the new belt, slide it onto the roller of the motor then onto the pulley of the agitator. Replace the beater bar in the housing. Start with the left end cap and make sure to keep the arrow pointing down on both sides of the part. Make sure that the agitator turns and center the belt before reattaching the cover.
While you have cover off, check for anything wrapped around the agitator. Remove anything that prevents the beater bar from turning freely. Make sure the area around the agitator is clear of any clogs.
However, if the belt is missing, the volume of dirt picked up will be less but not zero. It is more likely that the unit is clogged. There are several filters that need regular cleaning or replacement. The motor filter is at the bottom of the vacuum bag cavity. It should be cleaned with warm soapy water then rinsed completely. Squeeze out the excess water and then let it air dry. Wait until it is dry before reassembling the vacuum.
An exhaust filter also needs regular cleaning. This is behind the dust cover near the bottom of the area covered by the cover. To remove the dust cover, pull forward and then lay it down. To clean, put the filter under cold running water. Then air dry completely before reassembling the vacuum cleaner.
Finally check if the hose is clogged. First remove the hose by grasping it near the base and twisting it as you pull it away from the vacuum. Pull the hose completely straight then plug in and turn on your vacuum. Stretch out the hose and then let it relax into its storage configuration. Turn off the vacuum and then unplug it. Check for and remove any clumps of dirt stuck in the hose before replacing the hose.
If you have cleaned the vacuum and it is still not picking up dirt, try a different pile height setting on the vacuum. Also check if the agitator should be replaced.
Manage My Life has the manual for the vacuum here: http://www.managemylife.com/mmh/owner_manuals/15123/KENMORE-Vacuum-Upright-L0807740?brand_name_search=33078 . This manual gives the pictures of the various parts that need to be cleaned or replaced regularly. Sears Parts Direct has some parts for the unit; see http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/Model-72136078600/0582/0645000?sid=PDVertical .
I hope this helps.
Aug 03, 2011 | Kenmore 33078 Bagged Upright Vacuum
Kenmore upright Model 116 31912101 Brush doesn't turn. Little red reset pin doesn't move.
Something is jammed in it or the belt is bad.Turn it upside down.You will see 4-6 screws.Remove the screws and the plate they are holding.Now the brush is exposed.The belt hooks on to the brush and a small wheel on the other end.Remove the brush and belt.Make sure the area is free of debris.While you have it off,replace the belt.
May 16, 2011 | Kenmore 31913 Progressive Direct Drive...
Agitator doesnt turn
There is actually a reset button on the agitator, I would try pushing this switch first to see if this fixes it. The button is located on one of the sides of the agitator housing, I'm not sure if it's the left or the right side, or on the top of it.
Look on the sides of the part of the vacuum that is on the floor and see if you can see a small red pole on either side. If you can't find it here, look on the top of the part of the vacuum that touches the floor for a brush overload reset switch.
Try pushing that poll whenever you find it. This switch is a protection mechanism that will shut the brushes down to protect them if something gets vacuum up inside of the brush, it will automatically shut itself off to prevent any damage.
Simply push this overload switch down, and this should hopefully fix your problem.
If this didn't, please let me know and I can walk you through some more advanced troubleshooting.
If this was helpful, please be so kind and rate my repair, or leave feedback.
Thank you!
Chris Jones
GoVacuum.com
May 18, 2010 | Kenmore 31913 Progressive Direct Drive...
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Brush won't turn
The Agitator Overload switch is located on the top of the base assembly. Unplug the vacuum and press the reset button. The vacuum also has thermal protection, which will reset itself once the vacuum cools. The agitator will also stop when the vacuum is in the full upright position.
35922 Owner Manual
Feb 08, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Belt broken a a Kenmore model 116 canister vacuum
Greetings from GoVacuum.com,
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Vacuums
Belt constantly snapping
Make certain the belt is twisted the correct direction and that the brush is free to rotate. If the belt is twisted the wrong way it will probably come off or breake
Aug 30, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
788 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
